Reflashing PCM
Posted: Wed Jul 18, 2007 8:44 am
by Petrucci914
Is there a way to have the PCM re-flashed? I hate the shifting on my car and a mechanic told me that it seems like it needs to be re-programmed. He didn't have access to anything and said I'd probably have to contact a Pontiac Dealer...........which scares the hell out of me and they probably wouldn't be able to, or want to, do it.
Re: Reflashing PCM (Petrucci914)
Posted: Wed Jul 18, 2007 10:34 am
by BlueCrush
I would try a Toyota dealer. A Pontiac dealer would not have a clue. I have heard of estimates between $300 and $800 for a ECU reflash/reprogram from Toyota.
Re: Reflashing PCM (BlueCrush)
Posted: Wed Jul 18, 2007 10:48 am
by Raven
Quote, originally posted by BlueCrush »I would try a Toyota dealer. A Pontiac dealer would not have a clue. I have heard of estimates between $300 and $800 for a ECU reflash/reprogram from Toyota.That's a worse ripoff than a Unichip.
Re: Reflashing PCM (Sunny)
Posted: Wed Jul 18, 2007 10:51 am
by Mavrik
$300 to $800 to spend about an hour reflashing?whats the issue exactly that your mechanic feels a reflash is required for? perhaps have pontiac diagnose the concern and see if its a reflash or something else that is required to fix. A reflash usually either returns everything to an un-learned state. Or updates the programming. Its not always a "solve all" solution.
Re: Reflashing PCM (Mavrik)
Posted: Thu Jul 19, 2007 10:31 am
by Petrucci914
He drove it and said that there is nothing mechanically wrong with the tranny but said that it seems to shift early, so he knows what I'm talking about. He thinks the shift points are off and said a PCM reflash should do the trick. I wish there was a cheap or easy way to do it.
Posted: Thu Jul 19, 2007 10:45 am
by northvibe
you should also try a tranny drain and fill. or a full flush (non aggressive) that helps smooth the shifting. If you cant reprogram the tranny, look into a level 10 tranny or tranny parts (ie. torq converter)
Re: (northvibe)
Posted: Thu Jul 19, 2007 11:01 am
by Petrucci914
It's already been flushed and has full synthetic AMSOIL.
Re: (Petrucci914)
Posted: Thu Jul 19, 2007 11:19 am
by zionzr2
If you do go to a dealer...I go to Stark Pontiac in Sun Prairie. I have not had good service at Don Miller.
