motor mounts
Posted: Wed Jul 18, 2007 3:57 am
by hank the tank
I got my energy suspension motor mounts in today and the one small peace of paper that came in the box that they call instructions. Has anyone swapped motor mounts on there vibe.
Posted: Wed Jul 18, 2007 6:07 am
by WaveAction
i havent..but it aint really that hard i dont think...just take out one at a time..do one mount..then install that same one..and tighten it back up..then do the 2nd one...the engine wont fall or anything from removing just 1 mount...but then again i've worked with sunfires for the last 4 years
Re: motor mounts (hank the tank)
Posted: Wed Jul 18, 2007 6:11 am
by Herb
I'm still waiting for mine, but I thought they are added to either side of the existing mounts, not a replacement for them.
Posted: Wed Jul 18, 2007 7:54 am
by manicdan
the new ones should be a donut looking polyertherane(sp)one thats suposedly the pain is the back one cause u have to do it from under the car. but the rest seem to be simply use a jack to raise ur engine a half inch and replace it. u could probly find more at the matrix forums
Re: (manicdan)
Posted: Wed Jul 18, 2007 8:42 am
by Petrucci914
You don't replace them. What you bought are spacers/inserts that stiffen up the existing mounts. I think all it comes with are the front and back which are your torque mounts. You'll have to jack up the motor but be careful not to puncture your oil pan. The front one should be easy but you'll have to finesse (aka swear-a-lot) on the rear one. Make sure the car is cooled down because the rear one is by the first cat/manifold.
Posted: Wed Jul 18, 2007 9:01 am
by WaveAction
interesting..i'd have to get some and try it..got all the tools and a hoist at work so it makes it alot easier
Re: (RedFire2K)
Posted: Wed Jul 18, 2007 9:57 am
by Raven
You'll experience a lot of shake and rattle at idle but it's still worth it.
Re: (Sunny)
Posted: Thu Jul 19, 2007 3:11 am
by hank the tank
I took a look at the car and the front one is easy to get to. Not so much on the back one. There suppose to give a better launch .
Posted: Thu Jul 19, 2007 3:14 am
by northvibe
I hear using a car jack and so it can hold/lift the engine just a little so you can get to them makes it easy. There was a write up on matrixowners for that. I almost ordered them...eesm has some other poly mounts for suspension that i wanted to get, im still thinking about the engine mounts cuz my car is driven a ton so I dont want that shaking all the time.
Re: (northvibe)
Posted: Thu Jul 19, 2007 3:31 am
by hank the tank
I don't care about the shaking that much. I do it for the performance factor . Plus I want every ounce of power out of the car because I like beating the socks of of people in a wagon.
Posted: Thu Jul 19, 2007 3:35 am
by northvibe
lol yes these mounts well the engine ones are a good way to keep the tires on the pavement. I was looking for a engine damper but they dont make one yet for ours cars..... Now days I just need good mileage and handling.
Re: (northvibe)
Posted: Thu Jul 19, 2007 3:40 am
by hank the tank
Well one of my good buddy's has a 03 evo. It's hard to keep up with him on "drives". I hoping these help more than a little though.
Re: (hank the tank)
Posted: Thu Jul 19, 2007 3:49 am
by Whelan
I think it would hard to keep up with an Evo anyways regardless.
Re: (Whelan)
Posted: Thu Jul 19, 2007 3:52 am
by hank the tank
ya but I try .
Re: (northvibe)
Posted: Sun Sep 25, 2011 1:29 am
by cieglo
1. I realize this is an old thread, but I'm just getting around to it now.I tried to install my ES motor mount busing inserts today.1. Front: Not "easy" by my lazy-(removed) definition, but doable. Pull the mount out, break off that stupid little tack-on tab, accidentially break one fin of the fan shroud, use the long center bolt and some washers as a puller to pull the whole assembly back into place and voila! It looks sweet.The reaason I'm doing this is after my 3rd autoX event in my VGT I noticed a new squeak, Sherlocked that it was the motor mount and now I'm doing something about it. Moving on:2. Rear: only way to go: pull off driver's wheel, undo the center bolt with long extensions and a breaker bar. Undo the 3 nuts and 1 bolt holding the mount in place from under the car. Use a jack to shift the motor out of place, free up the mount and you have tight, tricky access to both sides of the mount.The Problem: Even though I could get to the mount, I could reach it, get the busing to it from both sides (left from driver's wheel well, right from under car) I could NOT get the bushings to seat into the mount. Each bushing has two "tabs." The top, wider, tab seated nicely, but the bottom tab would not go in. Due to the tricky access I could not get any muscle (not that I have any) on it and could not force it in.So, other than people that work for ES and say this is an "easy" job...has anyone done this and got it to work? Did you leave the rear mount "in place" or pull it al lthe way out of the engine bay to seat the busings?CAVEAT: it turn out my mount was squeaking because two of the rear nuts were loose! Yeah, seriously. I didn't get the rear bushing installed, but I got everything tight and the squeak is gone. Next weekend is the next AutoX event, wahoo!
