Lock button doesn't work, yet key fob does?
Posted: Sat Jul 14, 2007 1:59 pm
by guilty
Just noticed this today...I have been in the door panels recently changing speakers so I don't know if I messed something up. When i press the lock button inside, it won't lock the doors. If I press unlock, it works fine. The key fob works fine locking and unlocking. Any ideas?
Re: Lock button doesn't work, yet key fob does? (guilty)
Posted: Sun Jul 15, 2007 1:44 am
All doors affected or just one?
Re: Lock button doesn't work, yet key fob does? (ragingfish)
Posted: Sun Jul 15, 2007 1:47 am
by guilty
All of them
Posted: Sun Jul 15, 2007 1:56 am
by Waxler6942
you probably bent one of the connector terminals on the switch on either the front passenger or front driver door. I had a similar problem with a window switch.
Re: (Waxler6942)
Posted: Sun Jul 15, 2007 2:19 am
by guilty
Is it easy to fix or need to go to the dealer and have something replaced?
Re: (guilty)
Posted: Sun Jul 15, 2007 3:28 am
by Sublimewind
You have to figure out what's going on before we can tell you easy or dealer... It could be as easy as messing up a connection (pulled out) when you put the door panels back on..
Posted: Sun Jul 15, 2007 3:41 am
if memory serves me correctly, if the driver control panel is disconnected (or has a bad connection), all controls are affected. I would recommend removing the driver panel, checking the connector, ensuring no pins are bent out of shape, and then reseating the connector. If that doesn't resolve it, I would suggest a dealer visit. I don't believe an issue with the passenger door will affect all the other controllers...just it's own door.
Posted: Sun Jul 15, 2007 3:42 am
by Waxler6942
I would pull the door panels off the front two doors and look into the connectors and see if a pin is bent or pushed back into the housing. If you need a hand let me know where do you live in michigan??
Posted: Mon Jul 16, 2007 5:42 am
by guilty
Got everything fixed, thanks guys.
