Best pricebrand for clutch kit (GT)
Posted: Wed Jul 11, 2007 5:04 am
by robdog
I did some searching but did not really get what I was looking for. Who has changedupgraded their clutches. I have 90K and it is starting to slip a little. I want to upgrade to stage 1.What is the best bang for the buck for the whole clutch kit???Thanks.
Re: Best pricebrand for clutch kit (robdog)
Posted: Wed Jul 11, 2007 11:03 am
by Dezz1
I am glad you asked. I have an ACT street clutch and xtreme pressure plate. In addition, I had the flywheel turned. $500 to purchase the system, and $400 to install it.I am happy, and as to date I have to be careful to not spin the wheels during take offs. Also, when in motion and I stomp the gas (not often though) I burn a little rubber. The system was install in early April 2007.
Re: Best pricebrand for clutch kit (Dezz1)
Posted: Wed Jul 11, 2007 9:29 pm
by robdog
So your flywheel was good to go, no need to replace? Is there a break in period? Did you replace because yours was slipping or just because you wanted to upgrade?Thanks
Posted: Thu Jul 12, 2007 1:28 pm
by Dezz1
My flywheel had a groove in it that needed to be turned out. I changed the clutch and pressure plate because it started slipping a little bit during hard takeoffs up hill, and hard take offs going into a turn. Other than that the OE was fine.
Posted: Fri Jul 13, 2007 3:56 am
by robdog
Thanks for the info.
