Scion TC brakes on a Vibe?
Posted: Tue Jul 10, 2007 4:16 am
by Fred Allen Burge
Hello, Wondering if TC brakes can be used on a Vibe. I have TC wheels on my 04 Vibe and was curious if the brakes would be useful for replacements or even maybe they would be an upgrade?Thanks,Fred
Posted: Tue Jul 10, 2007 4:47 am
by northvibe
welcome to genvibe! that question I cannot answer... I am totally not sure if they use the same brakes :S The vibe does use the same brakes as a corolla or matrix though. So if you just wanted all disc then you could get a vibe gt brake set. The vibes stock brakes are pretty good already. even if you upgrade the rear (only base) drum brakes to disc they barely make a difference. Just make sure to have good pads and rotors in the front as they do most the work.
Re: (northvibe)
Posted: Tue Jul 10, 2007 5:09 am
by Fred Allen Burge
Thanks for the ideas, I'll look into the TC brakes and let you know if I find anything.Fred
Re: (Fred Allen Burge)
Posted: Tue Jul 10, 2007 6:38 am
by ~MRVIBE2006~
Just remember that the stock rims on a Tc are 17" (at least I think they are) so the rotors and calipers might require the 17" rim for clearence. Check before you buy unless you run 17" year round then you're fine.
