Oil/Transmission
Posted: Fri Jul 06, 2007 7:09 am
by PvtPetelka
So I was changing the oil and the oil filter (K&N all the way) and everything went perfectly. I drove my Vibe over to Advanced Auto to recycle the oil and it worked perfectly. I parked in the driveway and washed it, and when I went to pull back into the garage, the transmission wouldn't work. I can do park and N but thats all. This is an 04 Vibe. Can anyone help?
Re: Oil/Transmission (PvtPetelka)
Posted: Fri Jul 06, 2007 8:04 am
by kevera
Are you sure you changed the engine oil,and not the tranny fluid.What else could have possibly happened.
Re: Oil/Transmission (kevera)
Posted: Fri Jul 06, 2007 8:06 am
by PvtPetelka
I am 99.9% positive. Unless I somehow managed to drain the tranny and then fill the engine up without noticing a difference.
Posted: Fri Jul 06, 2007 8:23 am
by kevera
Was that the first time you changed your oil on the Vibe?Why don't you check the tranny dipstick to see what color the fluid is just for kicks.
Posted: Fri Jul 06, 2007 8:48 am
by PvtPetelka
This is the first time I changed the oil. I just got back from Basic Training and learned my car went to my sister, but they got me this "great" vibe. Haha, I like it mostly.Tranny is a little low, but not bad. If it drove, I would go get some fluid to top it off. To double check myself, where is the bolt for the oil located?
Posted: Fri Jul 06, 2007 8:55 am
by kevera
It's towards the passenger side,directly under the engine.The oil pan also has an indent in it where the 15mm bolt is.The tranny is on the drivers side.
Posted: Tue Jul 10, 2007 9:30 pm
by PvtPetelka
The tranny bolt had gotten loose and was leaking. I've tightened it and filled it, so its running like a dream again. Thanks!
Re: (PvtPetelka)
Posted: Tue Jul 10, 2007 10:09 pm
by KNINE
Don't you just love an easy fix?
