Painted the Plastic Engine Parts
Posted: Thu Jun 28, 2007 7:53 am
by chevelle_lover
I have noticed that some of you have painted the plastic engine parts. What kind of paint have you been using and is there anything else that I need to paint those parts.
Re: Painted the Plastic Engine Parts (chevelle_lover)
Posted: Thu Jun 28, 2007 8:08 am
by kevera
Some have painted,some have stickers.If your talking about the black engine cover.Then use krylon plastic paint.Some have prepped by sanding and some haven't,just using a plastic primer.
Re: Painted the Plastic Engine Parts (kevera)
Posted: Fri Jun 29, 2007 10:05 am
by mathteacher'04vibe
I tried Krylon for plastic and had horrible results--however, I did not sand first. I used some metallic paint and had good results after sanding, though. The big thing is...be patient and take your time. Don't do what I did and try to put 5 coats on in 10 min
Posted: Fri Jun 29, 2007 11:02 am
by AKLGT
i had already painted mine and had to repaint. i also used the krylon plastic coat paint on try 1, but it peeled badly and looked like poo. here is my how to on what i did for try #2. i did have to sand and primer.http://www.cardomain.com/ride/388840/6
Re: (AKLGT)
Posted: Fri Jun 29, 2007 11:16 am
by kevera
That weird,I painted with the primer and krylon plastic with sanding and it's still looks good,no peeling or cracking.I took my time though.It's been 2 years since I painted it.
Posted: Fri Jun 29, 2007 10:26 pm
by zionzr2
Seems to me the key is ..... and this is true with any type of painting .... and that would be proper preperation!
Re: (zionzr2)
Posted: Fri Jun 29, 2007 11:43 pm
by BlueCrush
Here is a good plastics painting guide from a guy on NewCelica.org: http://plaza.ufl.edu/dan131/In...d.htm
Re: (BlueCrush)
Posted: Fri Jun 29, 2007 11:55 pm
by chevelle_lover
I will give it a shot maybe the next weekend or so. (stereo install this weekend) The reason I asked is that I have painted the door panels on my 79 Pickup about 10 years ago and had horrible results. Right now it looks like that cheezy blue and grey cammo that some of the kids wear. I am going to Port Huron and I will have a look at some of the products over there.
