AC drain line clogged...
Posted: Sun Jun 24, 2007 1:34 am
by ajf3
...so I noticed water flowing from the passenger dash the other day. Figured it was a clogged drain line so I pulled it loose and tried to run a cable through it. The cable wouldn't go all the way through so I put it up on the ramps to check the other end. Found a 6" rachet extension stuck into the end of the tube!Is this some sort thing with mechanics when they do an oil change? Do they stick the extension in there while working on it if they don't need it?I recently had the oil changed at WalMart so I figure that's where it must have come from.I did want to check this though. On the underside it should just be a ~3" rubber tube hanging out, right? Wanted to make sure there wasn't a longer piece missing or something since it seems odd that they have it dripping right onto some undercarriage parts.
Posted: Sun Jun 24, 2007 6:10 am
yeah, that's normal (the short tube, not the tool in the hose!)what a bunch of rejects they got working over there. pretty impressive that thing stayed in there that whole time though. at least you got a free tool outta the deal!
Re: AC drain line clogged... (ajf3)
Posted: Sat Aug 18, 2007 8:47 am
by VIBE CAM
Just read ur post about AC drain line. Where do I find the upper and lower ends of the drain ? Any pics of the locations and how to access would be appreciated. Please reply directly to renman07-genvibe@yahoo.com so I'll have the best chance of seeing ur answer.
Re: AC drain line clogged... (VIBE CAM)
Posted: Sat Aug 18, 2007 9:39 am
by kevera
Didn't this happen to someone else a few years ago.
Posted: Sat Aug 18, 2007 9:49 am
by WaveAction
lol, thats to funny...
Re: (ragingfish)
Posted: Sat Oct 25, 2008 3:37 am
by dexner
Where is the Drain hose? I am having same problem
Re: (dexner)
Posted: Sat Oct 25, 2008 5:31 am
by hskater26
top left passenger side
