Just Bought an 03- What sounds are these?
Posted: Wed Jun 20, 2007 12:30 pm
by gillham
Hi all, This is my first post. I just bought an 03 baseline Vibe with 64k on it. I test drove it and had it checked out and everything seemed fine. However! The day after I bought it I left for a trip and came back 4 days later.The first drive was terrible. A gargling sound came from the engine when I put it in reverse and then continued as I drove around 20-30 around the block. Since then I've noticed the sound returns after it has been sitting overnight.Once the car has "warmed up" (shouldn't really be needed here in Texas), it drives really smooth.Any ideas on what this could be?Oil is good, but I'm 200 miles away from a change. Trans fluid is good.Thanks,Matt
Re: Just Bought an 03- What sounds are these? (gillham)
Posted: Thu Jun 21, 2007 10:58 am
by moongdss
Welcome to Genvibe! I haven't a clue what the sound could be, but the good folks here will have plenty of suggestions for ya soon.
Posted: Thu Jun 21, 2007 11:04 am
by northvibe
welcome!hmmm you should start the car put it in reverse and when you hear that sound, put it in park and leave it running, pop the hood and then poke around in the engine compartment to try to figure out what part is causing that. could be coolant that is low.....
Re: (northvibe)
Posted: Thu Jun 21, 2007 11:11 am
by Digger
How many miles are on it. It could be the front brake pads
Posted: Thu Jun 21, 2007 11:16 am
by Digger
Posted: Thu Jun 21, 2007 11:36 am
by zionzr2
Welcome!! To Our Vibedom!!I will be moving to Austin in August!I you get the sound issues solved soon. Yeah Coolant level check also check the A/C drain tube for blockages
Posted: Fri Jun 22, 2007 2:24 am
by ToolGuy
Yeah what Digger posted, check your belt!
Posted: Fri Jun 22, 2007 4:35 am
by coldmm803
welcome to the board
Posted: Fri Jun 22, 2007 7:56 am
by ajflan
Welcome to genvibe. I'm not sure what that sound could be.
Posted: Mon Jun 25, 2007 12:31 pm
by johnnymac
The sound could be a bad belt tensioner. The sound comes and goes at different speeds and thus rpms. Just a thought.
Re: (johnnymac)
Posted: Mon Jun 25, 2007 7:50 pm
by melders
welcome to the site!
Posted: Mon Jun 25, 2007 9:25 pm
by Sublimewind
Hi and welcome!Gurgling sound, like WATER gurgling? If so, check your coolant, you could be low. My Subaru does this all the time, but i know what that problem is.... Do you get a "water" wooshing sound when you rev the engine in park?
