How to Remove Rear Taillamp Lens/Housing 2006 Vibe?
Posted: Thu Jun 14, 2007 11:52 pm
by Justme
Anyone know the secret to remove the right rear lamp lens unit in a vibe? I have thereplacement part but can't figure out how to remove the damaged lens housing.Here's the part I'm speaking about.
Re: How to Remove Rear Taillamp Lens/Housing 2006 Vibe? (Justme)
Posted: Fri Jun 15, 2007 12:25 am
by Whelan
If its setup like the Trix. Pop your trunk/hatch and you will see the side access/storage panels, take those off and you either can reach in from there to loosen the screws or you may have to pull back the whole panel. Which is simple enough with a flathead driver a little finesse and some prying. Typically the taillamps are held on by either a few bolts or screws. My guess is they will be on bolts that are directly connected to the lamp housing and fitted through holes and nutted off. (no pun)
Posted: Fri Jun 15, 2007 11:36 pm
by Justme
Thanks. I was able to follow your directions yesterday and it was done in 5 minutes. Saved me lots of money I'm sure, not having to use a repair shop for this simple fix.
Re: (Justme)
Posted: Sat Jun 16, 2007 12:25 am
by zionzr2
one of the GM dealers around here charges around $90/Hour with a one hour minumum charge even if the repair would take 30 sec.Always nice to have the satisfaction of Doing it Yourself!!! You wallet sure thanks you!!
Re: (zionzr2)
Posted: Sat Jun 16, 2007 2:02 am
by kevera
Hey Is this a double post.I remember answering this yesterday
Posted: Sat Jun 16, 2007 2:05 am
by Justme
Yes it is, wasn't sure what catagory to use so I picked 2. Your directions were perfect & the job is done. Thanks
