Remove Rear Taillamp Lens/Housing 2006 Vibe
Posted: Thu Jun 14, 2007 11:49 pm
by Justme
Anyone know the secret to remove the right rear lamp lens unit in a vibe? I have thereplacement part but can't figure out how to remove the damaged lens housing.Here's the part I'm speaking about.
Re: Remove Rear Taillamp Lens/Housing 2006 Vibe (Justme)
Posted: Fri Jun 15, 2007 12:18 am
by NascarXprt
if you go in the back of the car, there is a compartment on the side right behind the tail lamp inside the car, remove the cover and there shows three screws and nuts, there is a white clip that is holding some wires, it just clips off and if it breaks no biggie. hope this helps, if not then i can go out and take a pic for you.
Posted: Fri Jun 15, 2007 12:49 am
by Justme
Thanks for the quick responce. Thw problem is that I look inside the compartment and don't see any screws. Now I'm wondering if I need to remove the entire panel inside the hatch area.What year Vibe are looking at?
Posted: Fri Jun 15, 2007 12:52 am
by kevera
It's easier to remove the panel.
Posted: Fri Jun 15, 2007 1:03 am
by Justme
So now how does that come off?
Re: (Justme)
Posted: Fri Jun 15, 2007 1:14 am
by kevera
I stand corrected,Nascarxprt was right.You have to shove your arm up threw that access cover.Feel around for the bolts.You will need a wrench to get at the nuts.
Re: (kevera)
Posted: Fri Jun 15, 2007 1:15 am
by kevera
It's a 10mm wrench,and don't drop your nuts.lol
Re: (kevera)
Posted: Fri Jun 15, 2007 1:23 am
by kevera
Or if you want to take the long route,here is how to get at it.I did this quick so,- remove the false floor, the nuts are in the tracks near the hinge- remove the tire tray insert, just unscrew the grey thing that holds the tray down and pull it out- Take out the cover over the other cargo box and unbolt everything in there and lift it out- pop out the quarter panel insert on the side and just gently pull on it by the edges, it will pop out. It's just held in by clips- reassemble the cargo area in reverse order.You don't have to remove the spare tire.
Re: (kevera)
Posted: Fri Jun 15, 2007 1:46 am
by NascarXprt
Quote, originally posted by kevera »Or if you want to take the long route,here is how to get at it.I did this quick so,- remove the false floor, the nuts are in the tracks near the hinge- remove the tire tray insert, just unscrew the grey thing that holds the tray down and pull it out- Take out the cover over the other cargo box and unbolt everything in there and lift it out- pop out the quarter panel insert on the side and just gently pull on it by the edges, it will pop out. It's just held in by clips- reassemble the cargo area in reverse order.You don't have to remove the spare tire.hahaha yea that is the reeeaallll looonng way. but yea you have to feel around to find them. stupid little compartment back.
Posted: Fri Jun 15, 2007 2:05 am
by Justme
Easy when you know how to get the old one out. Thanks to all the job is done. Can't imagine how much a repair shop would have charged for that 5 minute fix...
Re: (Justme)
Posted: Fri Jun 15, 2007 4:52 am
by Shadow-Vibe
They would have charges for a 2 hour job. HAHAHAHA No offense to all those mechanics out there
