Toyota HP Engine Kits
Posted: Fri Jun 08, 2007 8:42 am
by kevera
Here's a link for kits to rebuild our engines.They have a kit for the 1zz(base)#25 and a kit for the 2zz(GT)#30.It's a great way to cut the guess work out.The 1zz also have turbo kits.http://www.importperformancepa....html
Re: Toyota HP Engine Kits (kevera)
Posted: Fri Jun 08, 2007 12:28 pm
by ajflan
Good info. Wish I had money.
Re: Toyota HP Engine Kits (ajflan)
Posted: Fri Jun 08, 2007 1:52 pm
by CountryVibe
Looks like the kit it just for the bottom end of the engine.
Posted: Sun Jun 10, 2007 4:08 am
by Mario
Good find. I wonder how much labour would be to build up a 1zz engine. I basically use my vibe as a weekend car and I wouldn't mind having a turbo in there.
Re: (Mario)
Posted: Sun Jun 10, 2007 11:55 pm
by Whelan
they dont tell you what the hp gains are though?
Re: (Whelan)
Posted: Mon Jun 11, 2007 9:35 am
by Mario
Quote, originally posted by Whelan »they dont tell you what the hp gains are though?I believe they mention approximately 50%.
Re: (Mario)
Posted: Mon Jun 11, 2007 9:31 pm
by Whelan
So for about $1,000 I can get a 60hp gain? I would be pushing 187?
Re: (Whelan)
Posted: Mon Jun 11, 2007 9:53 pm
by GrayFox
Quote »Toyota HP Engine KitsIPP's High Performance (HP) Engine Rebuild Kits are designed for building motors for expected HP increases above stock. Our kits include everything you need to build and protect your motor from small to large HP ranges and up to 1000 HP (including use of turbochargers, Nitrous, Superchargers or all motor on gas)This is a build-up kit. It uses stronger internals so you can go for higher boost levels or do all motor applications with out as much risk as blowing your engine. I imagine the parts add a little power but not 60hp
Re: (ANO_Vibe)
Posted: Tue Jun 12, 2007 5:16 am
by Whelan
i was tryin to figure out even after i posted how those things can net you that much gain without a change of the entire intake manifold, exhaust system and turbo/sc additions.
Re: (ANO_Vibe)
Posted: Tue Jun 12, 2007 5:28 am
by Sublimewind
Quote, originally posted by ANO_Vibe » I imagine the parts add a little power but not 60hp That depends on weather or not you get the 11.1-1 C.R. pistons... the only way to make any REAL NA power is to bump up the compression ratio, well, and add cams, maybe a stroker kit.... So yea, 60hp seems doable with the 11.1-1'z Quote »i was tryin to figure out even after i posted how those things can net you that much gain without a change of the entire intake manifold, exhaust system and turbo/sc additions. Again, 11.1-1 C.R. pistons could do it... then you would most likely need a valve job and different cams to though... lets not forget the ARP head studs and any other fastener needed to handle 11.1-1 CR
Posted: Tue Jun 12, 2007 5:29 am
by mistertwo
if you look at the parts they offer a bigger bore and bump the compression up. that is how they squeeze the extra power out of the vibe gt is because the compression is steeper. kit #25 would net you some decent gains.. but you would have to have them install it, esp if it needs a bore
Posted: Tue Jun 12, 2007 5:32 am
by mistertwo
sublime beat me to it!
Posted: Tue Jun 12, 2007 5:35 am
by GrayFox
oh ok I didn't see the different piston options hahaThe compression ratio for a 03 GT is 11.50 - 1 so it's feasable that with that option, Whelan, you could have yourself a AWD GT or something very close at least.
Posted: Tue Jun 12, 2007 6:21 am
by BLAQJAQ
hmm i could see my self with some new parts for next season...really go for big boost...hmmmm...
Posted: Tue Jun 12, 2007 6:51 am
by keithvibe
ok, who is going to ask them to do a group buy on the oil filters?http://www.importperformancepa....htmlI could see myself buying one but not at that eye poping price tag.I would consider it, if it was under 45-50bucks.
Re: (Whelan)
Posted: Tue Jun 12, 2007 10:41 am
by Mario
Sorry, I was talking about the turbo kit. I internals alone would still add alot of power, but the main point would be to repare the car for boost.
Posted: Wed Jun 13, 2007 10:09 pm
by Sublimewind
Well to prep the car for boot your really need to drop the CR down to near 7-8.1-1 for thing to be proper, the drop in CR helps with preiginition of the already compressed mixture getting compressed up to critical mass before the spark...
Posted: Sun Jul 01, 2007 2:35 pm
by Mario
Has anyone around here built up their motor?
Re: (Sublimewind)
Posted: Wed Jul 11, 2007 10:37 am
by Dezz1
I have a question, I have been considering an Individual Throttle Body (ITB) but I am not sure of the gains, and would I get a large bang for the buck. Those things are around 2 grand a pop. Plus, would this damage the block due to lack of filter, and how about the air sensor?
Re: (Dezz1)
Posted: Wed Jul 11, 2007 9:31 pm
by Sublimewind
Unless your completely building the motor for N/A power individual throttle bodies are going to make your life a nightmare... You have all electronic control on the motor, including a input air sensor (MAF or MAP or the like) to consider, just taking that out of the loop is not going to work unless you step up to stand alone engine management.
Re: (Sublimewind)
Posted: Thu Jul 12, 2007 1:20 pm
by Dezz1
Thanks for the nightmare.
Re: (Dezz1)
Posted: Thu Jul 12, 2007 9:20 pm
by Sublimewind
Any time..
