Road Tar
Posted: Wed Jun 06, 2007 7:14 am
by TraySeeLea
Anyone have an easy method for removing road tar off the plastic lining/exterior?--and maybe even the tail pipe?
Re: Road Tar (TraySeeLea)
Posted: Wed Jun 06, 2007 8:23 am
by kevera
At the auto parts store,look for "Bug and Tar remover".It comes in a spray can.I've used "WD40" with good results also.
Posted: Wed Jun 06, 2007 9:34 am
by TraySeeLea
I've tried that (bug and Tar) but it didnt work super great. maybe I should try it again.
Re: (TraySeeLea)
Posted: Wed Jun 06, 2007 9:35 am
by kevera
Try "WD40" then,see if thats better.You will have to soak the area and let it sit for a few minutes to fully remove the tar.
Posted: Wed Jun 06, 2007 9:40 am
by TraySeeLea
haha i know....i try to be patient...but....
Re: (TraySeeLea)
Posted: Wed Jun 06, 2007 10:22 pm
by Whelan
double post, see below
Re: (TraySeeLea)
Posted: Wed Jun 06, 2007 10:23 pm
by Whelan
As for the tailpipe, get some triple 0 (says 000 on the package) Steel Wool. Pull a piece off and using that with some water clean off the pipe. Then with some metal polish, it will be shiny new.Clay Bar System. Autozone sells the Clay Magic stuff for about $10.Or get the Bug & Tar Remover, looks like this.
Posted: Mon Jun 11, 2007 1:07 pm
by gp20mushii
Posted: Mon Jun 11, 2007 2:03 pm
by nuvibe
You can also try 3M #8984. You can find it at your local automotive paint supply store. I work in one and I get people all the time that have this problem and I go out there and use it and it work's real good. Try it.....nuvibe
