Front Factory Splash Guard Problem
Posted: Wed May 30, 2007 9:17 am
by 04shadowvibe
When we got the new 06 Vibe in the fall we installed the GM splash guards. I did this on our 04 vibe with no problems. Now on the 06 idk if it was because it was cold out when i installed them but the large plastic push pin that goes into the bottom of the splash guard broke when i was installing it. I tried to find a replacement pin but i can not find one long enough or thick enough. It wasnt a problem until now when i noticed one of the fender screws holding the flap on fell out. SO where can i find a replacement plastic push pin that will fit? I hate to but a new set of splash guards for just 1 part.
Re: Front Factory Splash Guard Problem (04shadowvibe)
Posted: Thu May 31, 2007 1:29 am
by Whelan
Hmm, you do have a few options.1) use a cotter pin2) nut and bolt3) large wood screw3) 3M double sided tape4) dash of epoxy
