Is the lug pattern the same for a Vibe and Toyota corolla 1993.
Posted: Sun May 27, 2007 2:42 am
by whitevibe04
Just wondering if the pattern where the same for a Vibe and a Toyota Corolla 1993?
Re: Is the lug pattern the same for a Vibe and Toyota corolla 1993. (whitevibe04)
Posted: Sun May 27, 2007 5:54 am
don't know abouot a 93 corolla, but a 95 corolla has only four lugs per wheel
Re: Is the lug pattern the same for a Vibe and Toyota corolla 1993. (joatmon)
Posted: Sun May 27, 2007 5:55 am
by ajflan
I think the 93 has only four as well.
Re: Is the lug pattern the same for a Vibe and Toyota corolla 1993. (ajflan)
Posted: Sun May 27, 2007 8:24 am
by Viberrrr
Toyota Matrix Base/XR/XRS 2003-up (5x100mm / HPO / 12x1.5 Lug-nut / 54.06mm Bore)Toyota Corolla CE & LE 2003-up (5x100mm / HPO / 12x1.5 Lug-nut / 54.06mm Bore)Toyota Corolla S 2003-up (5x100mm / HPO / 12x1.5 Lug-nut / 54.06mm Bore)Toyota Corolla LE 2003-up (5x100mm / HPO / 12x1.5 Lug-nut / 54.06mm Bore)Toyota Camry 1986-1991 (5x100mm / HPO / 12x1.5 Lug-nut / 54.06mm Bore)Chevrolet Cavalier (all models) 1989-up (5x100mm / HPO / 12x1.5 Lug-nut / 57.10mm Bore)Chrysler Cirrus LX/LXI 1995-up (5x100mm / HPO / 12x1.5 Lug-nut / 57.10mm Bore)Chrysler Neon base LX 2001-up (5x100mm / HPO / 12x1.5 Lug-nut / 57.10mm Bore)Chrysler PT Cruiser 2000-up (5x100mm / HPO / 12x1.5 Lug-nut / 57.10mm Bore)Chrysler Sebring LX Convertible 2002-up (5x100mm / HPO / 12x1.5 Lug-nut / 57.10mm Bore)Chrysler Sebring LX Sedan/Plus 2002-up (5x100mm / HPO / 12x1.5 Lug-nut / 57.10mm Bore)Dodge Daytona Base 1987-up (5x100mm / HPO / 12x1.5 Lug-nut)Dodge Daytona Pacifica 1987-up (5x100mm / HPO / 12x1.5 Lug-nut)Dodge Daytona Shelby Z 1987-up (5x100mm / HPO / 12x1.5 Lug-nut)Dodge Neon (all models) 1998-up (5x100mm / HPO / 12x1.5 Lug-nut / 57.10mm Bore)Dodge Neon (5x100) 1995-up (5x100mm / HPO / 12x1.5 Lug-nut / 57.10mm Bore)Dodge Neon ACR 2001-up (5x100mm / HPO / 12x1.5 Lug-nut / 57.10mm Bore)Dodge Neon R/T 2001-up (5x100mm / HPO / 12x1.5 Lug-nut / 57.10mm Bore)Dodge Neon SE/ES 2001-up (5x100mm / HPO / 12x1.5 Lug-nut / 57.10mm Bore)Dodge Stratus Base 1995-up (5x100mm / HPO / 12x1.5 Lug-nut / 57.10mm Bore)Dodge Stratus Base with ABS 1995-up (5x100mm / HPO / 12x1.5 Lug-nut / 57.10mm Bore)Dodge Stratus ES 1995-up (5x100mm / HPO / 12x1.5 Lug-nut / 57.10mm Bore)Dodge Stratus SE/ES Sedan 2001-up (5x100mm / HPO / 12x1.5 Lug-nut / 57.10mm Bore)Dodge Stratus SE Plus Sedan 2002-up (5x100mm / HPO / 12x1.5 Lug-nut / 57.10mm Bore)Oldsmobile Achieva (all models) 1992-up (5x100mm / 12x1.5 Lug-nut / HPO / 57.10mm Bore)Oldsmobile Cutlass Calais (all models) 1985-up (5x100mm / 12x1.5 Lug-nut / HPO / 57.10mm Bore)Oldsmobile Cutlass Ciera 5x100 1984-up (5x100mm / 12x1.5 Lug-nut / HPO / 57.10mm Bore)Oldsmobile Firenza ) 1985-up (5x100mm / 12x1.5 Lug-nut / HPO / 57.10mm Bore)Plymouth Acclaim 1989-1995 (5x100mm / 12x1.5 Lug-nut / HPO / 57.10mm Bore)Plymouth Breeze 1994-up (5x100mm / 12x1.5 Lug-nut / HPO / 57.10mm Bore)Plymouth Laser 1985-1989 (5x100mm / 12x1.5 Lug-nut / HPO / 57.10mm Bore)Plymouth Neon Sport 5-lug 1994-up (5x100mm / 12x1.5 Lug-nut / HPO / 57.10mm Bore)Plymouth Sundance 1987-1994 (5x100mm / 12x1.5 Lug-nut / HPO / 57.10mm Bore)Pontiac Fiero 1984-1989 (5x100mm / 12x1.5 Lug-nut / HPO / 57.10mm Bore)Pontiac Grand Am 1985-1998 (5x100mm / 12x1.5 Lug-nut / HPO / 57.10mm Bore)Pontiac Sunbird 1985-up (5x100mm / 12x1.5 Lug-nut / HPO / 57.10mm Bore)Pontiac Sunfire 1995-up (5x100mm / 12x1.5 Lug-nut / HPO / 57.10mm Bore)Pontiac 6000 1982-1990 (5x100mm / 12x1.5 Lug-nut / HPO / 12x1.5 Lug-nut / 57.10mm Bore)Subaru Forester Base/S 1998-up (5x100mm / HPO / 12x1.25 Lug-nut / 56.15mm Bore)Subaru Impreza 1993-up (5x100mm / HPO / 12x1.25 Lug-nut / 56.15mm Bore)Subaru Legacy 1990-up (5x100mm / HPO / 12x1.25 Lug-nut / 56.15mm Bore)Subaru Outback 1995-up (5x100mm / HPO / 12x1.25 Lug-nut / 56.15mm Bore)Volkswagen Beetle (all models) 1998-up (5x100mm / HPO / 14x1.5 Lug-bolt / 57.10mm Bore)Volkswagen Corrado G60 1989-1992 (5x100mm / HPO / 12x1.5 Lug-bolt / 57.10mm Bore)Volkswagen Corrado SLC V6 1992-1994 (5x100mm / HPO / 12x1.5 Lug-bolt / 57.10mm Bore)Volkswagen Fox 1987-up (5x100mm / HPO / 12x1.5 Lug-bolt / 57.10mm Bore)Volkswagen Golf IV (all models) 1999-up (5x100mm / HPO / 14x1.5 Lug-bolt / 57.10mm Bore)Volkswagen Jetta IV (all models) 1999-up (5x100mm / HPO / 14x1.5 Lug-bolt / 57.10mm Bore)Volkswagen Jetta GLX VR6 1993-1995 (5x100mm / HPO / 14x1.5 Lug-bolt / 57.10mm Bore)Volkswagen Passat GLX VR6 1993-1995 (5x100mm / HPO / 14x1.5 Lug-bolt / 57.10mm Bore)
Re: Is the lug pattern the same for a Vibe and Toyota corolla 1993. (Viberrrr)
Posted: Sun May 27, 2007 8:26 am
by kevera
Great post,I think this should be made a sticky for future reference.
Posted: Sun May 27, 2007 8:27 am
by 02csnow
That is one big list.
Posted: Sun May 27, 2007 8:42 am
by nuvibe
Someone need's to find something to do. I do think you did your home work and then some.....nuvibe
Re: (nuvibe)
Posted: Sun May 27, 2007 8:49 am
by ajflan
That's lots of info, but I don't think that it answered the original question. Good info though. I agree that it should be sticky.
Posted: Thu Aug 02, 2007 12:39 pm
by sebdtw
Yes good information. Now that its here, could we get a brief explanation of what "(5x100mm / HPO / 12x1.5 Lug-nut / 54.06mm Bore)" means? For those of us who don't know...
Re: (sebdtw)
Posted: Thu Aug 02, 2007 9:05 pm
by ~MRVIBE2006~
As you have probably guessed, yes, the Tc rims will fit the Vibe. Here are the Tc rims on my 2006 Abyss Vibe with 225/45/17 tires. Got mine on eBay for $495.00.
Posted: Fri Sep 28, 2007 6:23 am
by leemur
So, simple question ....does that mean all those car wheels will fit a Vibe, or just the 12x1.5-54.** bores?
Re: (leemur)
Posted: Sat Sep 29, 2007 3:40 am
by ajflan
Our cars have a 5x100 bolt pattern. I am not sure of the stock offset, but I think tha 35-40 mm is a good range. Mine are 35mm.
Re: (ajflan)
Posted: Mon Dec 10, 2007 1:25 am
by dmsween
I use this guide and it's pretty accurate.It lists a 93 Corolla at 4x100Dan
Attached files WheelSizes.pdf (550.3 KB)
