Hit a huge racoon, BIG damage
Posted: Tue May 22, 2007 7:40 pm
by Raven
About 11:30pm last night I came over a large hill at about 60mph and just as I crested the hill BAM I nailed about a 30lb. racoon. Almost immediately the low washer fluid light came on and I knew there was trouble. It broke the bumper, knocked out the small lower right grill, popped the foglight loose, broke the washer pump, smashed the washer fluid tank and tore out the entire plastic fender liner. The fender liner got run over by several 18 wheelers. The grill is reuasable, I think. The metal Mr. Grill is folded in half but should be fixable. I have a GMC truck and a Subaru Outback which are both much higher and would not have been damaged but I happened to be driving the lowered Vibe. It could have been a lot worse. Around here there are more deer on the road than all other critters combined.
Re: Hit a huge racoon, BIG damage (Sunny)
Posted: Tue May 22, 2007 7:54 pm
by Sputnik
Wow big '(removed)! Sorry about the damage to your vibe. I once ran over an entire family of coons that were hanging out in the middle of the highway at 1am. Luckily (?) they were small and did no damage.
Posted: Tue May 22, 2007 11:00 pm
by vibe-04
It is hard to spot raccoons late at night. Too bad for the raccoon and your Vibe. I hit one in Nova Scotia on the Trans Canada highway with a rental car (a 300 I think) doing about 135 Km/H. Whack then thump, thump! No damage to the car except two of the push pins snapped on the front bumper. A
Re: Hit a huge racoon, BIG damage (13Vibe03)
Posted: Wed May 23, 2007 1:00 pm
by Whelan
large hill, 60mph, dark out all equal something not good. Kinda like when you get stuck behind the slow guy only to pass a cop around the bend. Some things just come with warnings.
Re: Hit a huge racoon, BIG damage (Whelan)
Posted: Wed May 23, 2007 9:18 pm
by Raven
Up here if you slowed down for every big hill, you would never get home before sunrise.
Posted: Wed May 23, 2007 9:43 pm
by Sputnik
Quote, originally posted by Sunny »Up here if you slowed down for every big hill, you would never get home before sunrise.So true. Same as where I grew up - all twisty hilly roads.
Re: Hit a huge racoon, BIG damage (Sputnik)
Posted: Wed May 23, 2007 10:44 pm
by Whelan
Im sure there are a ton of hills, I do feel bad you smashed up the car a bit, but is 60 a necessary speed when not on a highway? I rarely go over 40 on side roads and sometimes 50 on main ones, but for me 35-40 on most roads.
Posted: Thu May 24, 2007 8:29 am
by Mavrik
OUCH that hurts.I hit a racoon with my first car... wasn't lowered but I smelled burning meat for miles afterwards...
Posted: Thu May 24, 2007 9:30 pm
by mkaresh
I had no idea racoons could get that large, or do so much damage.
Posted: Fri May 25, 2007 12:22 am
by Raven
Quote, originally posted by Whelan »Im sure there are a ton of hills, I do feel bad you smashed up the car a bit, but is 60 a necessary speed when not on a highway? I rarely go over 40 on side roads and sometimes 50 on main ones, but for me 35-40 on most roads.I was on a main highway. It was 3 lanes wide actually, 2 north and 1 south.
Posted: Fri May 25, 2007 1:12 am
by slvrvibes
That is unfortunate about your car and the (removed).I didn't realize the racoons got that big. Usually when I see them around the neighborhood they look to be about 15-20 lbs.
Posted: Tue May 29, 2007 5:31 am
by NewNeptune
This thread is useless without pics!
