How do you remove the radio.
Posted: Mon May 21, 2007 6:11 am
by bmcm
I just bought a peripheral interface for my vibe and I don't know how to remove the radio. I am a visiual learner so if anyone has pics that would really help. Also has anyone hooked this to their system, and do you think an amature like myself can do it.My vibe is an 04 with the m&t package.
Re: How do you remove the radio. (bmcm)
Posted: Mon May 21, 2007 7:29 am
by kevera
Posted: Mon May 21, 2007 9:17 pm
by vibecrxsi240sxse
Just to let you know, I bought one of those interfaces from Best Buy that listed my '04 Vibe on the box. Bought it Friday May 19... last week.I too have the moon & tunes package, yet the installer couldn't get the interface to work. I do have a 100w amplified bazooka sub hooked to mine although that shouldn't matter in this case.Now, before we start bashing BB installers, he did tell me that this was the first time in 3 years of installing that he couldn't finish the installation. He did get the charging function to work but no sound ever came through the stereo from my ipod. I assume that is your goal with the interface.Please let me know if your Vibe worked with this interface 'cause I'll take it to a better installation place, maybe like tweeter or something.
Re: How do you remove the radio. (vibecrxsi240sxse)
Posted: Tue May 22, 2007 3:56 am
by kevera
Look through the"audio" section here.It gives you direction on how to hook it up.
Posted: Sat Nov 17, 2007 8:05 am
by northvibe
i just got the thing from a friend, wheres the best 12v constant power to use?
Posted: Sat Nov 17, 2007 8:26 am
by AKLGT
i know there is a good how to somewhere on this forum. i do know you have to pull the middle knob off so you can get to one of the screws.
Posted: Sat Nov 17, 2007 8:58 am
by northvibe
i have the radio out..didnt need to pull anything but the bezel and radio
Re: (northvibe)
Posted: Sat Nov 17, 2007 11:47 am
by DHelm72
Yep, The radio comes out in 5 minutes. Pull the bezel, unplug the accessory plugs and the HVAC vent control cable. Remove 4 screws holding in radio and you're done.
Posted: Sat Nov 17, 2007 2:42 pm
by northvibe
what..no thats not my question where do i put the peripheral 12v power....
Re: (northvibe)
Posted: Sat Nov 17, 2007 10:11 pm
by kevera
Quote, originally posted by northvibe »what..no thats not my question where do i put the peripheral 12v power....Battery power is the Blue/White (sometimes Blue/Yellow) wire on one corner of the larger 24-pin connector.
Posted: Sun Nov 18, 2007 1:49 am
by northvibe
is there a pinout of that 24pin plug? this is a generic ipod thing so i dont have the "vibe" pinout
Re: (northvibe)
Posted: Sun Nov 18, 2007 1:51 am
by kevera
Quote, originally posted by northvibe »is there a pinout of that 24pin plug? this is a generic ipod thing so i dont have the "vibe" pinoutWhat do you mean?I thought you wanted to hook up the 12volts.
Posted: Sun Nov 18, 2007 4:22 am
by northvibe
yeah..well when you say blue/white then sometimes blue/yellow that makes me think you arent 100% positive hahah. sooo i wanted a pinout so i know exactly what the 12v is.
Re: (northvibe)
Posted: Sun Nov 18, 2007 4:57 am
by kevera
There is only one wire with the blue/white or blue/yellow combo and it's on the end of the connector,it's hard to miss.If your not confident in that,then pull out a voltmeter and test it.But that's where I hooked mine up.
Posted: Sun Nov 18, 2007 11:33 am
by audiovibe
Someone ask for a radio pinout??? Battery BLUE/WHITE (+) RADIO HARNESS Accesory GRAY (+) RADIO HARNESS Ground BROWN (-) RADIO HARNESS Illumination GREEN (+) RADIO HARNESS Dimmer WHITE/BLACK (-) RADIO HARNESS Power Antenna BLACK (+) RADIO HARNESS Amp Turn On BLACK (+) RADIO HARNESS LF Speaker (+) PINK LF Speaker (-) VIOLET RF Speaker (+) LIGHT GREEN RF Speaker (-) BLUE LR Speaker (+) BLACK LR Speaker (-) YELLOW RR Speaker (+) RED RR Speaker (-) WHITE Amp Location UNDER FRONT PASSENGER SEAT Aron
Re:
Posted: Mon Nov 19, 2007 2:58 am
by Silverado Man
I'm looking to order the iPod2car adapter what part #'s do I need? In the applications list on there site it only shows 2004-2005. I just want to get the right part #'s before I order.
Re: Re: (Silverado Man)
Posted: Mon Nov 19, 2007 3:18 am
by kevera
Did you read this thread,3rd post down.It's shows compatible years.http://forums.genvibe.com/zerothread?id=21818
Re: (audiovibe)
Posted: Mon Nov 19, 2007 4:32 am
by northvibe
Quote, originally posted by audiovibe »Someone ask for a radio pinout??? Battery BLUE/WHITE (+) RADIO HARNESS Accesory GRAY (+) RADIO HARNESS Ground BROWN (-) RADIO HARNESS Illumination GREEN (+) RADIO HARNESS Dimmer WHITE/BLACK (-) RADIO HARNESS Power Antenna BLACK (+) RADIO HARNESS Amp Turn On BLACK (+) RADIO HARNESS LF Speaker (+) PINK LF Speaker (-) VIOLET RF Speaker (+) LIGHT GREEN RF Speaker (-) BLUE LR Speaker (+) BLACK LR Speaker (-) YELLOW RR Speaker (+) RED RR Speaker (-) WHITE Amp Location UNDER FRONT PASSENGER SEAT AronThanks Aron! Kev. and you are right, looks like i need to tap a roo on that blue/white. I can finally put it together today!
Re: (northvibe)
Posted: Mon Nov 19, 2007 4:46 am
by kevera
Wuhoo!
Re: Re: (kevera)
Posted: Mon Nov 19, 2007 5:01 am
by Silverado Man
Ok great post. Looks like it will work. So I basically will need the PXDP adapter with the PXHGM3 harness? Thanks.
Re: (northvibe)
Posted: Mon Nov 19, 2007 5:57 am
Quote, originally posted by northvibe »yeah..well when you say blue/white then sometimes blue/yellow that makes me think you arent 100% positive hahah. sooo i wanted a pinout so i know exactly what the 12v is.From http://forums.genvibe.com/zero...61195Quote, originally posted by ragingfish »When I pull out my radio, there's a 24 pin connector back there...In addition, here's the pin diagram from the service manual:
Posted: Mon Nov 19, 2007 8:21 am
by northvibe
they are using some odd colors...brown for ground and blue/white for power...whateva ill go try it in a min...
Posted: Mon Nov 19, 2007 8:31 am
by northvibe
Re: (northvibe)
Posted: Mon Nov 19, 2007 8:34 am
by kevera
Stop procrastinating and get your (removed) outside and do it.
Re: (kevera)
Posted: Mon Nov 19, 2007 8:40 am
by northvibe
Quote, originally posted by kevera »Stop procrastinating and get your (removed) outside and do it.dude...if i got all my projects done...what would i have to look forward to and tell my fake gf im to busy to watch chick flick tv's with her.
Re: (northvibe)
Posted: Mon Nov 19, 2007 8:46 am
by kevera
Ummm.....fake girlfriends,too much info.
Posted: Mon Nov 19, 2007 9:34 am
by northvibe
uhhhh didnt work yet.. i check dip switches
Posted: Mon Nov 19, 2007 9:45 am
by northvibe
uhhh crappy, i dont have a splice thingy..........uuuuuuuuuuuuuuhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
Posted: Mon Nov 19, 2007 10:38 am
by northvibe
ok got it working, with temporary engineering skills...until turkey weekend i can properly splice that awesome little wire.
Re: (northvibe)
Posted: Mon Nov 19, 2007 10:51 am
by kunkstyle
Quote, originally posted by northvibe »ok got it working, with temporary engineering skills...Bubblegum, tin foil, and a paper clip?
Re: (kunkstyle)
Posted: Mon Nov 19, 2007 1:42 pm
by northvibe
Quote, originally posted by kunkstyle »Bubblegum, tin foil, and a paper clip?and a pencil
Re: (northvibe)
Posted: Mon Nov 19, 2007 2:14 pm
Quote, originally posted by northvibe »and a pencil hopefully a dixon ticonderoga #2.my personal testing has shown that no other pencil lasts in a jury-rigging scenario.
Re: (ragingfish)
Posted: Mon Nov 19, 2007 11:16 pm
by northvibe
Quote, originally posted by ragingfish »hopefully a dixon ticonderoga #2.my personal testing has shown that no other pencil lasts in a jury-rigging scenario. hahha nice, well it works well, but charges my ipod/iphone even if the car is off...so i just I just have to unplug the ipod/iphone every time i turn the car off :/
