Torque #'s
Posted: Sun May 20, 2007 8:22 am
by Vibe_dude
So I am about to do a brake job.can anyone tell what the torque # for the calipers are...i know that the rims are 76lbs.but need to make sure everything is put back on right.
Re: Torque #'s (Vibe_dude)
Posted: Sun May 20, 2007 9:02 am
by kevera
ah...Till there tight.I don't go by #'s,just real tight.
Posted: Sun May 20, 2007 2:00 pm
by trimovingxr
looks like front caliper bolts = 25 ft.lbs.http://www.illformedpragma.com...n.pdf
Posted: Fri May 25, 2007 2:11 am
by Sublimewind
Make sure you don't lube any of the bolts you are torquing... Seriously, it changes the spec by reducing friction and can change DRASTICLY... like say for instance 25ftlbs without lube to 75+ftlbs WITH lube... Just a quick tip...
