Hvac door actuator
Posted: Thu May 17, 2007 11:26 am
by lars_seg45
How do you replace the hvac door actuator motor without taking the dash out??I have tryed with a 1/4 flex shaft on the top bolt with no luck so far.
Posted: Thu May 17, 2007 11:41 am
by engineertwin2
I tried to do it without removing the dash, but it was well worth the hassle of pulling the dash - MUCH EASIER...that's all I can really say...way too difficult to do without removing the dash.By the way, welcome to genvibe!
Re: (engineertwin2)
Posted: Fri May 18, 2007 7:05 am
by DopeVibeGT
Curious, why does yours need replaced? Ever since I turned the AC on this year a week ago, I get a 'clicking' noise from the dash, like a vent keeps opening and closing. It goes away if I turn on the cabin recycling button thingie.
Posted: Tue May 22, 2007 12:53 am
by engineertwin2
Bingo! That was what prompted me to replace it DopeVibeGT...the limit switches burn out on the actuator and it sits there and continues to try and open and close the damper. The part is between $35 and $50 (different Pontiac dealerships) and believe it or not it wasn't cheaper at Toyota in my neck of the woods.I put in some photos on here somewhere...
Re: (engineertwin2)
Posted: Tue May 22, 2007 8:44 am
by tinder
i'm having the same problem, and I've had the part sitting in my glove compartment for the past month trying to figure out how change out the part.Do you have a link to how to remove the dash?Thanks.
Re: (tinder)
Posted: Tue May 22, 2007 10:14 am
by kevera
Ask and you shall receive,thanks to Raging.http://forums.genvibe.com/zero...29847
