Turbo timer?
Posted: Fri May 11, 2007 11:29 am
by CountryVibe
I am new to having a car that has boost and i was wondering if i should get a turbo timer for the carThis is not for the vibe > it's for the laser i just picked upIf you have used them befor,is there any brands i should look at and are they easy to install?
Posted: Fri May 11, 2007 1:26 pm
by AKLGT
unless you know what you're doing with a turbo timer, DO NOT get one. people will over boost and blow up their cars (not warrantied) with them. best bang for your buck is going with a proven engine management. what vehicle is this for??
Re: (AKLGT)
Posted: Fri May 11, 2007 2:26 pm
by CountryVibe
i though the timer was for letting you take the key out, but lets the car run for a few mins to cool down the engine?
Posted: Fri May 11, 2007 4:25 pm
by AKLGT
*edit*i'm thinking of a boost controller....Quote »Turbo timerFrom Wikipedia, the free encyclopediaJump to: navigation, searchA turbo timer is a device designed to keep an automotive engine running for a pre-specified period of time in order to automatically execute the cool-down period required to prevent premature turbo wear and failure. After a period of driving when a turbocharger has been working hard, it is important to let the engine run at idle speed for a period of time, allowing the compressor assembly to run down in speed and cool from the lower gas temperatures in both the exhaust and intake tracts. At the same time the lubricating oil from the engine is able to circulate properly so the turbine won't burn the lubricating oil that would otherwise be trapped within the charger with the turbine rotating at high speed. With regard to modern automotive turbochargers, the need for a turbo timer can be eliminated by simply ensuring the car does not produce any 'boost' (during driving) for several minutes prior to the ignition being shut off.
Re: (AKLGT)
Posted: Sat May 12, 2007 12:02 am
by Mavrik
well in most cases the turbo timers installed on subarus also come with boost control... not sure about a Vibe one though.
Re: (CountryVibe)
Posted: Sat May 12, 2007 1:04 am
by coldmm803
Quote, originally posted by CountryVibe »i though the timer was for letting you take the key out, but lets the car run for a few mins to cool down the engine?yes, that is exactly what a turbo timer does. you could get an aftermarket alarm system w/ remote start which has the option of the turbo timer. i'd say check out viper alarms
Re: (coldmm803)
Posted: Sat May 12, 2007 1:44 pm
by CountryVibe
thank you for the help, I look at viper. I was going to get an alarm so i had a remote to open the doors, i am worried about the turbo over heating because i going to use the laser for work to keep some miles off the vibe, i so used to jumping out and turning off the car so i been looking in to these.
Re: (CountryVibe)
Posted: Sun May 13, 2007 9:14 am
by satur9
yeah i have the viper alarm it has a turbo timer function.if your getting a alarm its your best bet.
Re: Turbo timer? (13Vibe03)
Posted: Sun May 13, 2007 12:17 pm
by CountryVibe
i think it's both water and oil cooled but i'll have to look at it when i get it back it's in the shop while the redo the head gasket, port and cut the head and replace all the seals in the engine
