dirty seats
Posted: Mon May 07, 2007 6:04 am
by discojunkie76
just wondering what the best methods are for cleaning the seats (laundry detergent has so far failed)
Posted: Mon May 07, 2007 6:57 am
by engineertwin2
I've always used the "dry clean in a can" method. Usually, I just buy a carpet/upholstery cleaner at AutoZone...that usually does the trick.I once got gum on the seats and that required me getting some dry ice and freezing the goop off (ok, freeze it then scrape it almost perpendicular with a credit card or other). I had tried ice, but all it seemed to do was melt when removing gum.I would think a carpet shampoo machine would also work well, so long as you could vacuum out the water...
Re: (engineertwin2)
Posted: Mon May 07, 2007 7:11 am
by kevera
Seat covers hide the dirt.Cheers.
Posted: Mon May 07, 2007 7:26 am
by ashleymc_38
my seats are horribly stained too. I have two little sisters that are the two biggest pigs in the world...so yes i'm also looking for a way to get them looking black again. Hoping there is a cheaper alternative besides seat covers
Re: (ashleymc_38)
Posted: Mon May 07, 2007 7:29 am
by kevera
If you can find this stuff,it works great and is cheap.It took vegetable oil and camping dirt off all my seats and is great for the headliner.http://www.folex.net/
Re: dirty seats (discojunkie76)
Posted: Mon May 14, 2007 1:55 pm
by SpencerPz01
There are number of upholstery cleaning agents available. Try using a spray cleaner from Turtle Wax. Simply spray evenly on the seat or door upholstery and rub vigorously. Then, wipe it thoroughly with a dry cloth. If problem not solved, I suggest you switch to leather Toyota Seat Covers. It's easier to clean and maintain than a normal fabric car seat covers.
