underbody plastic
Posted: Sun May 06, 2007 7:25 am
by melders
anyone know were i can get my hands on one of the plastic screw pin like things that hold the plastic on the underbody of the vibe? one came off on my passenger side front, and it seems like the whole front end is loose, and it moves quite a bitEDIT: this picture shows were it is looseit is the clip that is farthest left, and the whole pass side front end seems to move because that piece is missing
Posted: Sun May 06, 2007 12:34 pm
by ramenboy...
http://forums.genvibe.com/zerothread?id=9923hey melders try this link. its the parts list from ragingfish. there's a bunch of 'retainers'listed....look up front fender or something like that. i think they're all similar pieces. one of them broke on my rear bumper fascia. cost $10 for that little piece at the dealergood luck
Re: (ramenboy...)
Posted: Sun May 06, 2007 7:39 pm
by kevera
That's totally weird.I had noticed 3 missing on mine when I put my body kit this weekend,and was wondering where to buy them.Thanks for bringing the topic up.
Re: (kevera)
Posted: Sun May 06, 2007 7:54 pm
by 02csnow
Quote, originally posted by kevera »That's totally weird.I had noticed 3 missing on mine when I put my body kit this weekend,and was wondering where to buy them.Thanks for bringing the topic up.When did you get a body kit?
Re: (kevera)
Posted: Sun May 06, 2007 9:43 pm
by melders
Quote, originally posted by kevera »That's totally weird.I had noticed 3 missing on mine when I put my body kit this weekend,and was wondering where to buy them.Thanks for bringing the topic up.any thing i can do to help its just that i realised that my whole pass front end was rattling, that could the the noise that i hear at about 20-30mph
Re: (kevera)
Posted: Sun May 06, 2007 9:51 pm
by melders
kevera, did you order them? which ones did you get? let me know if they are the right ones
Re: (melders)
Posted: Sun May 06, 2007 10:21 pm
by kevera
I am going today or tomorrow for them.I think the same one on mine is missing,as the pass side rattles too.I will let you know part #'s and price.Quote, originally posted by 02csnow »When did you get a body kit? I had it for a while now,just lazy to put it on.Looks good on,but the front is real low,have to watch for speed bumps and curbs.It's the GM sport package.
Re: (kevera)
Posted: Sun May 06, 2007 10:53 pm
by melders
Quote, originally posted by kevera »I am going today or tomorrow for them.I think the same one on mine is missing,as the pass side rattles too.I will let you know part #'s and price.awesome, thanks!
Re: (melders)
Posted: Mon May 07, 2007 12:17 am
by michaelgt
Mine was missing and the front end was rattling. My tire rubbed on the plastic and wore a hole into the fender lining. I ended up putting a zip tie into the hole to hold it for know.
Re: (michaelgt)
Posted: Mon May 07, 2007 1:17 am
by ZubenElGenubi
Quote, originally posted by michaelgt »Mine was missing and the front end was rattling. My tire rubbed on the plastic and wore a hole into the fender lining. I ended up putting a zip tie into the hole to hold it for know.(removed)..that exactly the same thing that happened to my front left wheel well plastic! I'm having a devil of a time finding a replacement part. I've zip-tied mine as well, but it won't last long.
Re: underbody plastic (melders)
Posted: Mon May 07, 2007 1:43 am
by kevera
I think this is the number,I can't confirm but I think it is.Part #88970767Here's a link,
http://www.gmpartsdirect.com/results.cfm,I want to find the Toyota #,as they will be cheaper.
Posted: Mon May 07, 2007 3:38 am
by engineertwin2
Anyone checked for generic plastic body clips from say Ace Hardware or True Value? When I was performing some routine maintenance on a friend's Honda CRV, I noticed some were missing and just grabbed a few at the Ace Hardware around the corner...
Re: (engineertwin2)
Posted: Mon May 07, 2007 12:41 pm
by ZubenElGenubi
Quote, originally posted by engineertwin2 »Anyone checked for generic plastic body clips from say Ace Hardware or True Value? When I was performing some routine maintenance on a friend's Honda CRV, I noticed some were missing and just grabbed a few at the Ace Hardware around the corner...Are you serious? Ace Hardware? A new Ace just opened up about a mile from my house. I'll have to go by there tomorrow and check 'em out. Thanks for the tip.I'm gonna need a whole new liner though ($93 List, $124 from gmdirect with crazy shipping). I wonder if a used one from a junkyard would suffice?I'd use Pam's Auto (the site that BlueCrush found), but they only have an entire fender ($175).
Re: (ZubenElGenubi)
Posted: Mon May 07, 2007 7:43 pm
by kevera
They should carry them at most auto supply stores.I found some at partsource for $1.They have a few sizes and look the same.
Re: (kevera)
Posted: Mon May 07, 2007 8:02 pm
by melders
Quote, originally posted by kevera »They should carry them at most auto supply stores.I found some at partsource for $1.They have a few sizes and look the same.hmm...so autozone should have them right?
Re: (melders)
Posted: Mon May 07, 2007 9:26 pm
by scherry2
I was looking at the GM inner liner on a vehicle today and I noticed that the GM liner seems a lot thicker and sturdier, and the push clips fit alot tighter than the liner on my vibe. the one on my vibe seems real cheap in comparison to another GM model. just an observation.
Posted: Tue Aug 28, 2007 4:47 am
by duck3
Another easy quick fix that was way cheaper was using zip ties. I ended up fixing my mom's doing that and then when I looked at mine to check if I was missing any, I found about 4 or 5 missing....my entire front fascia would move when I washed it with a sponge! I used some zip ties and the front end is now sturdier than it ever was with those plastic bolts!
