Removing Factory Sub
Posted: Sun Apr 29, 2007 3:30 am
by loochador
Just wanting to remove the factory sub that came with my vibe but instead of just diving in and taking things apart I dont need too, what all is there to remove? Anyone have pictures to support them.
Re: Removing Factory Sub (loochador)
Posted: Wed May 02, 2007 1:26 am
by Vibr8tr
There was a thread around here somewhere that shows one that is out. I can't imagine it's hard by looking at it.HOWEVER, if you decide to take it out... would you be willing to sell it???
Re: Removing Factory Sub (Vibr8tr)
Posted: Thu May 03, 2007 10:46 pm
by Whelan
If your getting rid of it for a aftermarket setup Ill buy the plastic molding and basically everything for it and trade you the stock paneling.
Re: Removing Factory Sub (Whelan)
Posted: Fri Nov 16, 2007 12:50 pm
by DHelm72
I removed mine and installed a pioneer shallow 10" sub under the back panel next to the spare tire. You can't even see my sub, it is totally stealth. The factory sub comes out easily. All you have to do is remove the rear side panel in front of the sub. You have to remove the storage lid for the spare tire compartment, the small storage lid and bin behind the rear seat and loosen the plastic trim by the door right rear door. You also have to remove the 4 tie down hooks on the right side. Then the panel pops right out. The sub is secured by several bolts. Maybe 5 or 6 but it is pretty obvious when you get in there. All the bolts for the deck lid and storage bin behind the rear seat are in obvious locations. There are no tricky, hidden screws or bolts. Sorry Whelan, I use the empty speaker grille as a port for my sub to emit bass since it is hidden behind that area.
