What Oil & filter do YOU use?
Posted: Sun Apr 29, 2007 2:55 am
by truckdriver402
Hi all,I'm new to the Vibe and new to this forum. I'm surious as to what kind of oil and oil filter you use. Since I was in high school, I've ALWAYS used Pure One oil filters. I also own a 1991 Geo Storm with 196k on it (which I attribute to my oil, filter, and good ol' Japanese engineering!).The manual says to use 5w-30. However, I have always heard that when you get some miles on a car, you should bump up to 10w-30. Do let me know!
Re: What Oil & filter do YOU use? (truckdriver402)
Posted: Sun Apr 29, 2007 4:18 am
by djb383
PureOne by Purolator.........the long one, PL14477.
Posted: Sun Apr 29, 2007 7:23 am
by northvibe
I also use the Purolater long life one by pureone for a filter. For oil its usually the plain valve 1 or mobile 5w-30.
Re: (northvibe)
Posted: Sun Apr 29, 2007 8:21 am
by tcam
K&N Filter with 10W-30 which I know is ok to use as long as you're not in really cold weather.
Re: (tcam)
Posted: Sun Apr 29, 2007 9:32 am
by djb383
Even if 0W-30 or 5W-30 had better flow characteristics than 10W-30 at 75F? All 3 have the same viscosity at 212F.
Posted: Sun Apr 29, 2007 9:36 am
by VivaVibe
I am using Mobile 1 Full Synthetic 5w30, and a Purolator PureOne #PL14477 filter. I think you're better off staying with what is recommended since it was designed for that weight oil.
Posted: Sun Apr 29, 2007 9:54 am
by djb383
This might change your mind about going to 10W. Most of your wear occurs when the engine is at less than operating temp. 0W-30, 5W-30 and 10W-30 are the same thickness at normal operating temps but the 0W and 5W oils will start the lubrication process quicker at below normal operating temps than 10W will because they flow better at lower temps.http://63.240.161.99/motoroil/
Posted: Sun Apr 29, 2007 10:27 am
by DavidPIL
K&N HP-1002 and Royal Purple 5w30. Used to use Red Line 5w30 but it's very difficult to find w/o having to order online.The K&N Filters have a 1" nut molded into the end so all you need to remove it is a 1" socket. Very convenient.Dave
Posted: Sun Apr 29, 2007 10:32 am
by nygiantzz1
I use Castrol GTX 5W-30 and a K&N filter.
Re: What Oil & filter do YOU use? (djb383)
Posted: Sun Apr 29, 2007 11:22 am
by tcam
Quote, originally posted by djb383 »This might change your mind about going to 10W. Most of your wear occurs when the engine is at less than operating temp. 0W-30, 5W-30 and 10W-30 are the same thickness at normal operating temps but the 0W and 5W oils will start the lubrication process quicker at below normal operating temps than 10W will because they flow better at lower temps.http://63.240.161.99/motoroil/What if u live somewhere that currently doesn't ever drop below 50 degrees, and reaches 90 degrees on a daily basis?
Re: What Oil & filter do YOU use? (tcam)
Posted: Sun Apr 29, 2007 12:48 pm
by Digger
5w-30 with a phram filter. I also used the Purolator PureOne filter when the phram is not in stock.
Posted: Sun Apr 29, 2007 10:41 pm
by djb383
Quote, originally posted by tcam »What if u live somewhere that currently doesn't ever drop below 50 degrees, and reaches 90 degrees on a daily basis?Regardless of the ambient temp, 0W and 5W will flow quicker to dry engine parts at start-up than 10W will. At 212F 0W-30 is just as thick as straight 30 weight so you don't have to worry about having too thin an oil in your Arizona heat.If and when 0W-XX dino oil is introduced, you can bet the auto manufacturers will recommend it because it flows quicker than 5W-XX and especially 10W-XX at less than normal engine operating temps. Currently 0W-XX is only available in synthetic so most manufacturers aren't going to require the use of synthetic oil but it does provide superior flow characteristics at less than normal operating temps.
Posted: Sun Apr 29, 2007 11:05 pm
by northvibe
If I lived in a warm climate I'd run synthetic. In MN with synthetic it takes a lot longer for the engine to warm up as there isnt as much friction so on those cold winter mornings it sucks to drive twice as far without heat than with the dyno oil stuff.
Re: (northvibe)
Posted: Mon Apr 30, 2007 12:02 am
by djb383
Hummmm, I believe most of the heat generated is from the combustion process, not friction. When it's extremely cold, it'll take any engine, regardless of what oil, longer to reach operating temp. The main advantages of synthetic vs dino is its ability to flow at low temps and it's ability to resist breakdown at extreme high temps, 300F plus. There is very little difference in friction reduction between the two, a lot less friction is a myth.
Re: (djb383)
Posted: Mon Apr 30, 2007 12:04 am
by Whelan
Toyota OEM Filter, Castrol GTX 5W-30., 3,000 miles.
Posted: Mon Apr 30, 2007 12:35 am
by KNINE
Quote, originally posted by djb383 »PureOne by Purolator.........the long one, PL14477.The long one? I use the PureOne filter listed in the oil filter book at the autoparts store. I don't remember the part number off the top of my head, but I don't think I'd call it long. Is there more than one size filter? I have the base engine.
Re: What Oil & filter do YOU use? (K-NINE)
Posted: Mon Apr 30, 2007 12:40 am
I think the Purolator PureOne PL14477 is their oil filter spec'd for the GT/2ZZ engine, and it will fit a Base/1ZZ, but is a little bit longer, so it holds a bit more oil, and also should have more filter elements inside, theoretically providing better flow, less resistance to impeded flow from the filter elements becoming restricted by filtered particles.I have a base, and use the PL14476, and castrol GTX 5W-30
Posted: Mon Apr 30, 2007 1:48 am
by djb383
Exactly what joat said. The 77 is slightly longer than the 76. The 77 and 76 will fit either engine.
Posted: Mon Apr 30, 2007 8:14 am
by Cougar Vibe
Does anyone know if the Matrix/Corolla now use 5w20? I thought when they did their engineering trick w/a bigger sump via a shorter dipstick, they began pushing 5w20. Oh, and as others have said, the 2ZZ filters not only offer more filter/filtration, they offer you a nice 4qt oil change. I use the longer OEM one...I bought a case off Ebay from Rusty Wallace Toyota for $29.
Posted: Mon Apr 30, 2007 8:20 am
by scott_h
Amsoil with either Napa Gold or WIX.
Re: What Oil & filter do YOU use? (Digger)
Posted: Mon Apr 30, 2007 8:21 am
by scott_h
Quote, originally posted by Digger »5w-30 with a phram filter. I also used the Purolator PureOne filter when the phram is not in stock. You might want to do some reading - Fram gets terrible reviews in terms of quality (or lack there of)...
Posted: Mon Apr 30, 2007 9:09 am
by truckdriver402
I didn't realize so many people used Pure One! I've tried to turn as many on to it as I can. As for me, I use Valvoline Max Life 5w-30 with a Pure One filter PL14476.
Posted: Mon Apr 30, 2007 10:18 am
by zionzr2
Purolator Pure One and Mobil 1 5w-30
Posted: Mon Apr 30, 2007 10:39 am
by GMJAP
Valvoline synthetic 5W-30 and OEM filters.My previous car was a 1991 Geo Storm! Had well over 100K on it.
Re: What Oil & filter do YOU use? (GMJAP)
Posted: Mon Apr 30, 2007 11:04 am
Quote, originally posted by GMJAP »My previous car was a 1991 Geo Storm! Had well over 100K on it. My current car is a 2003 Pontiac Vibe and it has well over 100K on it (140K)
Re: What Oil & filter do YOU use? (joatmon)
Posted: Mon Apr 30, 2007 1:02 pm
by GMJAP
Quote, originally posted by joatmon »My current car is a 2003 Pontiac Vibe and it has well over 100K on it (140K)Posted that cause truckdriver402 said he also has a 1991 Geo Storm with beaucoup miles.I'll be keeping my Vibe till well over 100k too, probably well over 150k.
Posted: Tue May 01, 2007 12:14 pm
by truckdriver402
Quote, originally posted by GMJAP »Valvoline synthetic 5W-30 and OEM filters.My previous car was a 1991 Geo Storm! Had well over 100K on it. My 1991 Geo Storm still runs great and still doesn't use a drop of oil or smoke. I have about 196,000 miles on it. Problem is, it won't pass PA inspection as the struts are shot...I should've kept an Ohio tag on it!
Posted: Tue May 01, 2007 2:51 pm
by ehoff121
Mobil 1 5W-30 synth and Mobil 1 filter
Posted: Wed May 02, 2007 1:08 am
by Al 03VibeGT
Purolator PureOne and synthetic 5w - 30 (usually Pennzoil Platinum as PepBoys usually has ridiculous sals on it approx. $1.50/ qt)
