Rear sway bar?
Posted: Mon Apr 23, 2007 9:51 am
by Zac86
took a quick look under my 06 vibe to see what kind of suspension setup it has because I was thinking of buying a sway bar but all I could see was a torsion beam with some sort of black beam inside it I guess to add stiffness? Is this correct what i'm seeing and is there any aftermarket sway bar I could add onto it?
Re: Rear sway bar? (Zac86)
Posted: Mon Apr 23, 2007 10:08 am
by 02csnow
Quote, originally posted by Zac86 »took a quick look under my 06 vibe to see what kind of suspension setup it has because I was thinking of buying a sway bar but all I could see was a torsion beam with some sort of black beam inside it I guess to add stiffness? Is this correct what i'm seeing and is there any aftermarket sway bar I could add onto it?the black bar that you saw inside of the torsion beam is your rear sway bar. Neverenoughauto.com has a replacement for it made by Progress. The bar is thicker and gives up better handling. I just put mine on this weekend and felt alot of difference in roll.
Posted: Mon Apr 23, 2007 10:13 am
by northvibe
for sure a good upgrade you can either get only the rear by progess, or a full front and rear sway bar set from hotchkis or TRD (said to be the same....but I do not know my self). neverenough should have both, rear only or the set.
Posted: Mon Apr 23, 2007 10:32 am
by Zac86
i'm still not convinced that it's a sway bar, looks more like a trailing bar.
Posted: Mon Apr 23, 2007 11:13 am
by northvibe
heres the link at neverenoughhttp://neverenoughauto.com/cat....htmlits just a oem replacement, but thats the set and then just the progress rear sway bar.
Re: (Zac86)
Posted: Mon Apr 23, 2007 11:15 am
by Raven
It's a sway bar unless there are a lot of confused companies making them and confused customers buying them. I'm confused, I have a progress rear sway bar.
