small leaks around sunroof seal
Posted: Thu Apr 12, 2007 12:11 am
by mixer
The seal is in excellent shape, but I have noticed at the rear corner of the passenger side there is a small amount of leakage(rain, carwash). Is there any adjustments that can be made? I thought the sunroof might not be seating properly. The seal is not cracked or torn.
Re: small leaks around sunroof seal (mixer)
Posted: Thu Apr 12, 2007 12:39 am
by djb383
It's my understanding this is normal as there are drain tubes in the channel that allow this small amount of leakage to drain away.
Re: small leaks around sunroof seal (djb383)
Posted: Thu Apr 12, 2007 12:44 am
by scherry2
Quote, originally posted by djb383 »It's my understanding this is normal as there are drain tubes in the channel that allow this small amount of leakage to drain away.yep there is.now is it leaking onto the interior of the car?
Re: small leaks around sunroof seal (scherry2)
Posted: Thu Apr 12, 2007 2:33 am
by mcgusto82
the drain tubes must be clogged. i've seen this happen. Try a wire hanger, straighten it, and try to clear it out before you start movign your sunroof.
Posted: Thu Apr 12, 2007 2:45 am
by djb383
If it's not leaking into the interior of the car, the drain tubes are doing there job.
Re: small leaks around sunroof seal (mcgusto82)
Posted: Thu Apr 12, 2007 3:36 am
by SeattleJeremy
You might want to try a fuzzy pipe cleaner before sticking a jagged wire hanger up there.
