1zz engine in 06 vibe
Posted: Wed Apr 11, 2007 10:46 pm
by oldgizer
How can I increase the rpm"s above 6300? Is there an attachment to overide the ecu?
Re: 1zz engine in 06 vibe (oldgizer)
Posted: Wed Apr 11, 2007 11:39 pm
by BlueCrush
You would have to change out a couple chrystals inside your ECU. It will completely remove your rpm limiter. Not recommended!! People who have done it have blown their engines due to revving too high.
Posted: Thu Apr 12, 2007 12:44 am
by djb383
At 6300 rpm you've gone past max torque and horsepower so why go even farther past them?
Posted: Thu Apr 12, 2007 8:16 am
by Lancer
Also, you'll be running the risk of floating a valve at those high rpms. If your getting 'bigger' cams I can see raising the rpms a little. But on a stock 'ish' engine I agree that it wont do you any good. The easiest way to raise the rpm limiter is to go with a stand alone ecu.
