Scion supercharger?
Posted: Wed Apr 11, 2007 12:17 pm
by 4azdmunky
So this looks like it would fit our cars, anyone look at these yet? Really its nothing more than a turbo with the exhaust hooked to a belt:http://cgi.ebay.com/ebaymotors...sting
Re: Scion supercharger? (4azdmunky)
Posted: Wed Apr 11, 2007 4:13 pm
by tcam
hmmm, interesting idea. But I don't think the TC's engine is a 1zz-fe. I think it's a 1JZ or something.
Posted: Wed Apr 11, 2007 4:29 pm
by AKLGT
i believe they are different engines than the 03-06 Vibe/Trix
Posted: Wed Apr 11, 2007 6:37 pm
by northvibe
scion is a 2.4L ? I-4 and ours is a 1.8L, different engines but they do look similar. so this SC wouldnt fit, there is a centrifical SC a member here has one, blanking on the name though as its almost 5am!
Posted: Thu Apr 12, 2007 7:48 am
by Lancer
The Scion TC has a 2,362 cc 2.4 liters in-line 4 front engine with 88.5 mm bore, 96 mm stroke, 9.6 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder 2AZ-FE Unleaded fuel 87 Fuel economy EPA highway (mpg): 30 and EPA city (mpg): 23 Multi-point injection fuel system 14.5 gallon main unleaded fuel tank Power: 119 kW , 160 HP SAE @ 5,700 rpm; 163 ft lb , 221 Nm @ 4,000 rpm And, NO, that supercharger wont work unless you have brackets to mount it and a creative way to hook up the pulley. It's not very big either. Probly only get 25 more hp near redline.Get this one instead:http://cgi.ebay.com/ebaymotors...QrdZ1$999 right now!
Re: Scion supercharger? (Lancer)
Posted: Thu Apr 12, 2007 12:31 pm
by 4azdmunky
WOW thats not a bad price. How come that didnt come up when i searched by "vibe supercharger"? I search several times a week with that search criteria and usually pull back crap like the electric supercharger.
Posted: Thu Apr 12, 2007 2:17 pm
by Lancer
Cuz it was just posted 2night.
Posted: Thu Apr 12, 2007 8:23 pm
by Raven
It must have been on an early '05 with cable throttle. It doesn't say if the car was auto or manual. If you are going to bid, you should clarify that with the seller. I bought a set of front calipers with pads (like new)for my truck from them for $60.00 shipped. They are reliable to deal with.
Re: Scion supercharger? (13Vibe03)
Posted: Fri Apr 13, 2007 10:36 am
by 4azdmunky
(from the limited amount of research I have done) The only thing that looks like we might need (if you dont already have) is exhaust upgrade to 2.25-2.5".For 05 DBW, someone was making adapter plates for the DBW TB. Oh, and a new belt.
Posted: Fri Apr 13, 2007 10:38 am
by 4azdmunky
LOL oh I see the easy answer.... iD10T error: Error resides between keyboard and chair.
Posted: Tue Apr 24, 2007 5:43 am
by sagekai
Quote, originally posted by Lancer » Probly only get 25 more hp near redline. I think the Scion S/C takes it from 160 hp to 200...
