GPS Antenna On/Off Switch
Posted: Mon Apr 09, 2007 11:32 pm
by ProtonXX
Anyone ever tried this before or know if this is possible? I need a switch because my GPS system turns the DVD/Input video off when the car is moving. The only way to trick it is to unplug the GPS antenna.
Re: GPS Antenna On/Off Switch (ProtonXX)
Posted: Mon Apr 09, 2007 11:53 pm
by Whelan
check ebay, Pioneer used to make a bypass for cars with dvd/nav combos
Re: GPS Antenna On/Off Switch (Whelan)
Posted: Tue Apr 10, 2007 5:54 am
by ProtonXX
Found a better solution, moved the mute wire to a the pin above it & grounded it. Everything works now :D
