K&N Intake Price
Posted: Wed Apr 04, 2007 1:53 am
by bull77
I'm shopping around for an intake for my '06 base. Hoping to get this installed over the summer. Wondering if $275CDN + tax is overpriced for an K&N intake or will this work?
http://cgi.ebay.ca/Racing-Cold...wItemAlot cheaper
Posted: Wed Apr 04, 2007 2:08 am
by coldmm803
yes, that cosmo would workyou could try doin a search for more info, a few people have used the cosmo intakeswith the k&n you would also need an additional breather filter for the fat hose coming out under the valve cover, the additional breather filter would be about $15-20. i dont think the cosmo ones need it, they are made for the 05+*****editbreather filter in pichttp://forums.genvibe.com/zerothread?id=23919
Re: (coldmm803)
Posted: Wed Apr 04, 2007 3:17 am
by kevera
Cosmo intakes are good for the price.I have one,but on an 04.I know a few guys had problems with fitment.
http://www.cosmoracing.com/pro...=1258
Re:
Posted: Wed Apr 04, 2007 9:00 am
by keithvibe
I have a cosmo on my 06 awd and did have fitment issues. To get it to fit properly you will need to take off the front bumper and driverside headlight to get everything lined up correctly. You will even need to cut some of the second peice of piping on the cosmo if you upgrade to an AEM dryflow filter and ditch their crappy filter.I ended up cutting off about 2inchs off one end and 4 inches off the other to get the dryflow to fit nicely above the fog light.
Re: Re: (keithvibe)
Posted: Wed Apr 04, 2007 10:21 pm
by Petrucci914
You'll have to cut the piping on ANY Vibe CAI. They were made for the Matrix but the Vibe has the fog lights in a different area. You'll usually have to cut about 2-3 inches off or more if you have the Throttle Body Spacer.
Re: Re: (Petrucci914)
Posted: Thu Apr 05, 2007 3:48 am
by kevera
Quote, originally posted by Petrucci914 »You'll have to cut the piping on ANY Vibe CAI. They were made for the Matrix but the Vibe has the fog lights in a different area. You'll usually have to cut about 2-3 inches off or more if you have the Throttle Body Spacer.No,I have a cosmo and it fits perfectly,no cutting and I still have room before it hits the foglight.All I have to do to clean the filter is take the 2 screws off the lower black cover and Voila.
Posted: Thu Apr 05, 2007 3:49 am
by AKLGT
keep looking in the for sale forums. a used intake is just as good as a new one. you can always take the tube into the local K&N filter distributor and buy a new filter. otherwise, they are just as good after a cleaning.
Re: K&N Intake Price (bull77)
Posted: Sat Apr 07, 2007 3:03 am
by MAVibe
I have a cosmo on my '06 base and had no fitment issues....didn't need to cut anything, or customize anything...... it just fit right on.
Re: K&N Intake Price (MAVibe)
Posted: Sun Apr 08, 2007 5:55 am
by Petrucci914
But did you have to choke the filter onto the pipe? I had it working on mine at first also but the filter had to be choked up over the pipe.........not good. I ended up cutting a lot. It is possible that they now make intakes for Vibes that are different than the Matrix. Early on they used the same ones for both - not a good idea.
Re: K&N Intake Price (Petrucci914)
Posted: Sun Apr 08, 2007 6:41 am
by kevera
Nope,tons of room.No choking up.They must be made for the Vibe.When did you buy yours.
