				There's a hole in my hatch panel!
				Posted: Tue Apr 03, 2007 11:10 am
				by breezd
				My vibe came with a nice, softball sized, hole in the plastic panel on the inside of the hatch...Would a junk yard be my best bet for replacing the panel?  What would be a fair price for them to charge me?  The yard here has about a dozen Vibe's on the lot, most with little rear damage if any.  Is there a difference between panels during different years or between Base/GT?  Is it difficult to remove the panel?Thanks in advance...Dan
				Re: There's a hole in my hatch panel! (breezd)
				Posted: Wed Apr 04, 2007 7:04 am
				by breezd
				anyone?
				Posted: Wed Apr 04, 2007 7:17 am
				by scherry2
				yes a junkyard would be your best bet. I cracked mine 2 to 3 years ago and just under $200 was the price then from the dealer new  no difference between years or models even trix's(taken from another thread)[let say your sitting in the cargo area with the hatch closed.the are 3 tabs acrossed the top one in the middle and 2 about an inch in from each side.don't pry on the bottom of the panel there hooks down there.]its just push pinned on, you should be able to just pull on it and it will pop offwhere was the hole? anything behind it? you might keep it in case you want to mount speakers or maybe a sub in the hatch.
				Posted: Wed Apr 04, 2007 8:32 am
				by ColonelPanic
				Try to locate a wrecked Vibe at
http://www.car-part.com would be my suggestion, then start calling around to see if they have that trim piece.Scherry2's right - no difference between models or model years for the panel.  Either color interior will have the same trim back there as well.  So that really ups your chances of finding what you need.
				Posted: Wed Apr 04, 2007 8:40 am
				by keithvibe
				if your handy.. you could fiber/glass it over... filler/prime and paint... while your at it fg in some new subs LOL
				Re: There's a hole in my hatch panel! (keithvibe)
				Posted: Fri Apr 06, 2007 5:11 am
				by Whelan
				Lucky for you the cars came in one interior color scheme, makes life much easier in the searchl.
