Ingalls Stiffy Torque Damper - Colorado Owners Read!
Posted: Mon Apr 02, 2007 2:14 pm
by Petrucci914
Us owners with Automatic Trannys need this!
http://www.ingallseng.com/parts/ETD/stiffy.htmAnybody in Colorado able to provide a test vehicle?
Posted: Mon Apr 02, 2007 2:31 pm
by northvibe
Ive been looking at getting or making one of these! I ask Weapon-R if they were making one for the corolla/trix/vibe and they said no. Then asked if I could buy just the damper so I could make my own brackets and got no response. These are good for automatics because autos dont have the esmm's (after market engine mounts) like the manual does. If it was a resonable price Id get one, or atleast the damper to make my own moutn kit.
Re: (northvibe)
Posted: Tue Apr 03, 2007 1:44 am
by Petrucci914
Ya, I wonder how hard it would be to make the brackets. How much does Weapon-R charge because those Ingall ones are rediculously expensive.
Posted: Tue Apr 03, 2007 2:31 am
by northvibe
weapon r wont quote me on just the damper, but for a kit that should be a good fit after fabbing brackets:SCION XB / XA 2003-05 959-111-103 $160 SCION TC 2004+ 959-111-114 $200 So they are cheaper but I am unsure of weapon r's quality on the damper itself.I could probably have my uncle fab the brackets if I got a damper no problem. But the Ingall damper looks to have better quality than the weapon r one :s I suppose you do get what you pay for.
Re: Ingalls Stiffy Torque Damper - Colorado Owners Read! (Petrucci914)
Posted: Tue Apr 03, 2007 12:43 pm
by 4azdmunky
Hell yea, I'll try it. How much and where do i sign up?
Posted: Tue Apr 03, 2007 12:49 pm
by 4azdmunky
NEVERMIND, found it, signed up.
Re: Ingalls Stiffy Torque Damper - Colorado Owners Read! (4azdmunky)
Posted: Tue Apr 03, 2007 12:57 pm
by Petrucci914
Excellent, Smithers. Excellent.
Posted: Tue Apr 03, 2007 1:04 pm
by 4azdmunky
I ated the berry ones, they tasted like burning.
Posted: Thu Apr 05, 2007 5:26 am
by satur9
you smell like mommy's kisses.
Re: Ingalls Stiffy Torque Damper - Colorado Owners Read! (satur9)
Posted: Fri Apr 06, 2007 1:11 pm
by 4azdmunky
and over there is where I saw the leprican. he tells me to burn things........"Ahhh right laddy, ye know know what te do, ...burn it, burn it all"
Posted: Thu Apr 12, 2007 10:55 pm
by Petrucci914
Looks like they have one for the Altis (Japanese Corolla). I'm trying to find out if it will fit.
http://www.9thgencorolla.com/f...53935
Posted: Fri Apr 13, 2007 1:17 am
by northvibe
Looks like it needs diy brackets or something that makes it hard to install? so...i guess we are still on the look out :/ When i get some time ill see if my uncle can help me fab some brackets, just need a damper to test them on :s
Re: (northvibe)
Posted: Fri Apr 13, 2007 3:14 am
by Petrucci914
I believe it's designed to screw onto the side of the block and then onto the firewall. That picture shows all that you need. It all depends where they choose to install it on the car. But I'm not 100% sure.
Posted: Fri Apr 13, 2007 4:15 am
by northvibe
yea from what ive seen of ones for the celica (c-one brand) they go from the left side (passanger) to the strut tower mount.
Posted: Sun Sep 09, 2007 10:21 am
by 4azdmunky
These guys screwed me over big time. I was contacted about my R56 Mini Cooper S. They wanted to borrow my car to take some measurements and make some new products. They would then call me back in a few months for a fitting, I would drive on the new parts for month, give them feedback and I would keep the prototypes. So I took my car up to them since they are local. They kept the car for almost a week. When i got it back the gear shift knob was loose, which later it turned out to be broken. Last month when I was under the Mini I noticed that one of the body plates under the driver side front wheel is missing (several bolts hold it on so it did not fall off), and the clamp that slides and holds the intake vacuum hose is missing. Its been 6 months now and no contact, no reply to emails or anything.Do NOT do business with these guys.
Posted: Tue Sep 11, 2007 4:36 am
by Sublimewind
I have something else for all of you to consider...
http://www.taylordevices.com/tayd.htmMakers of industrial motion control... they are in Tonawanda NY, about 3mi from where i used to live and right in mistertwo's back yard...
