TRD Cold Air Intake!!!!
Posted: Mon Feb 24, 2003 1:19 pm
by redtrdmatrix
Matrix TRD Cold Air IntakeNow available for the first time from TRD is a Cold Air Intake for the Toyota Matrix. Designed to fit all Matrix models (no 4WD), TRD’s Cold Air Intake offers up to 11 additional horsepower and 9 lb.-ft of torque. The intake features an aluminum tube, powder-coated in candy apple red with a reusable, high-flow conical air filter. The longer, smoother intake tube improves cylinder fill rates which in turn maximizes power potential. The new Cold Air Intake is fully warranted and emissions legal in all 50 states.
Re: TRD Cold Air Intake!!!! (redtrdmatrix)
Posted: Mon Feb 24, 2003 11:02 pm
by DABEAR95
Why don't you post the link if you have one, so others can take a look...
Re: TRD Cold Air Intake!!!! (DABEAR95)
Posted: Mon Feb 24, 2003 11:58 pm
by Frosty
Here is some info on http://www.MatrixVibe.nethttp://www.mat ... php?t=2102 They are clamoring for pics too. Otherwise all the info is there...
Re: TRD Cold Air Intake!!!! (silverawd26)
Posted: Tue Feb 25, 2003 6:53 am
by millster
This is being discussed at MatrixVibe.net. A Toyota rep is going to bring it up to TRD and get more info, possibly look for a volunteer for testing.
Posted: Tue Feb 25, 2003 9:01 am
by millster
True. It was made very clear that the TRD warranty for this product would not apply to the Vibe.
Posted: Tue Feb 25, 2003 9:11 am
by millster
Yes, but another thing that was brought up today is whether GM SPO may rebrand the TRD CAI for their own use. I doubt they would, but we can always hope.
Posted: Tue Feb 25, 2003 9:19 am
by millster
The pics are here!!!!!!(From MatrixVibe.net)
Posted: Tue Feb 25, 2003 9:35 am
by millster
No problem! I just happened to flip over to that page and there was the post! The job hunt is going, still nothing yet though. I'm still moving when the house sells though.
Posted: Tue Feb 25, 2003 9:44 am
by millster
Me too. I'm sure it will though. Thanks!!!!!
Posted: Wed Feb 26, 2003 9:13 am
by MadBill
"Wonder why the CAI would not work for the AWD Vibe? Doesn't the Injen work for the AWD? Chances are the TRD CAI, like all the others, WILL fit the AWD just fine! Likely the issue is that Toyota doesn't WANT it to have more power, since one popular explanation of its 7 HP lower output is that the AWD system can't handle any more...
Posted: Thu Feb 27, 2003 7:05 am
by MadBill
That's the other explanation I've heard. Would be nice to A: compare underhood appearance to see if there's any apparent reason why a 2WD CAI wouldn't fit the AWD and B: compare the two exhaust systems, say dimensionally and by measuring the back pressure. If the power loss is just the exhaust, a cat back system done right should really help the AWD! Of course, Toyota could have deliberately restricted the exhaust to reduce the power for durability reasons...
Posted: Mon May 12, 2008 1:38 pm
by waveresponder
after brief search on CAI this is the only thread on the TRD CAI I can find....anyone install this in their vibe?will it fit a 2007 fwd base with fog lights?asking this cuz I though I remembered reading somewhere it doesnt fit in those that have factory foglights?
Posted: Mon May 12, 2008 3:08 pm
by AKLGT
I had one on my 03 VGT. Not sure if it will fit your 07 base vibe or not. but definitely NOT on the GT models. The air pump from 04+ years on the 2zz made the piping different.don't know if the 1zz guys had this issue or not, but my 2zz threw a CEL as did most everyone else with the TRD intake. Not until I got the Unichip did it fix it.
Posted: Mon May 12, 2008 10:14 pm
by northvibe
TRD cai will not fit the 05 DBW and up models. Toyota never made a intake for the 05+ and up.
Posted: Tue May 13, 2008 3:38 am
by AKLGT
get an Injen intake. much better and didn't throw a CEL.
Posted: Tue May 13, 2008 3:43 am
by northvibe
did they make one for dbw? thought cosmo was the way to go if you had dbw.
Re: (northvibe)
Posted: Tue May 13, 2008 3:47 am
by Kamikaze
AFE SRI worked w/o any CEL... I had to slightly modify it, by using a air breather off the head and plug the inlet on the intake where the air breather normally would go.
Posted: Tue May 13, 2008 3:48 am
by AKLGT
don't know. But on NA motors, I would go CAI vs SR. more power and better results.
Re: TRD Cold Air Intake!!!! (waveresponder)
Posted: Wed May 28, 2008 5:41 pm
by waveresponder
couldnt you just buy it and cut it to the length of a short ram?
