Lineage Ground Wire Kit Installed
Posted: Thu Mar 29, 2007 12:23 am
by BlueCrush
I installed a Lineage Ground Wire Kit this past weekend. It is a 5 wire, 4 gauge kit. Nice, high quality kit for only $45 on Ebay. There are 5 wires in this kit(18", 22", 26", 32", 38"). They are 4 Gauge ground wires, versus smaller 8 gauge kits, platinum dipped ends and sealed soldered connections. This is one of the best kits out there.Here is how I wired mine:From Negative battery terminal:To driver's side chassis:To Tranny:To rear valve cover:To passenger's side chassis:To Alternator bracket:And here is an overall pic:
Re: Lineage Ground Wire Kit Installed (BlueCrush)
Posted: Thu Mar 29, 2007 12:38 am
by kevera
Great work B/C.Did you notice a difference in your idle.I want to do this but only if it smoothes my idle out a little.
Re: Lineage Ground Wire Kit Installed (kevera)
Posted: Thu Mar 29, 2007 1:40 am
by BlueCrush
Quote, originally posted by kevera »Great work B/C.Did you notice a difference in your idle.I want to do this but only if it smoothes my idle out a little.I haven't noticed a big change in the idle. I know that the warmer the temps get outside, the better my idle gets. It was 81° on Monday here and the idle was super smooth. I'll check it again today since it is only 47° and report back.EDIT: I checked the idle a little bit ago and is idling a little smoother than before. I am also getting a little better shifing and less static on a couple radio staions. So, overall I think it is worth $45.
Posted: Thu Mar 29, 2007 7:00 am
by tcam
looks great Brian I made the the mistake of having one of my ground points at the exhaust manifold, which was very stupid. After 3 or 4 months, the wire was partially melted onto the heat shield, and the end of it was all deformed. lol, should've just ran it to the tranny like u did.
Posted: Thu Mar 29, 2007 7:22 am
by shane_c
So what is this supposed to do?
Posted: Thu Mar 29, 2007 1:23 pm
by XRTIM
Agreed...excellent work! I especially like the "pics". They will be a great help when I install mine. Thanks BC!
Re: (shane_c)
Posted: Thu Mar 29, 2007 1:36 pm
by tcam
Quote, originally posted by shane_c »So what is this supposed to do?-gain small torque and hp-better mileage-better throttle response-smoother idle-reduced emissions-brighter headlights-reduced audio noiseall of these things may or may not be noticeable, but that is what extra ground wires are advertised to do. For me, the smoother idle and acceleration is what I was able to notice.
Posted: Fri Mar 30, 2007 2:49 am
by Raivis
do the kits come with instructions??? if so could someone post them. i was thinking about buyign some 4 GA for this. just don't know which wires are being replacedhope headlights are brighter if i roll up two windows at the same time my lights dimm some
Re: (Raivis)
Posted: Fri Mar 30, 2007 4:27 am
by BlueCrush
Quote, originally posted by Raivis »do the kits come with instructions??? if so could someone post them. i was thinking about buyign some 4 GA for this. just don't know which wires are being replacedhope headlights are brighter if i roll up two windows at the same time my lights dimm someThere are no wires being replaced. All existing wiring stays. You are just adding these ground wires to your engine bay.
Re: (BlueCrush)
Posted: Mon Apr 16, 2007 10:19 am
by 02csnow
Hey Brian i just got my ground kit today and plan on doing it this weekend. Just wondering what lengths you used for each contact point and if you had any other pics.
Posted: Mon Apr 16, 2007 10:30 am
by damronjr
For some reason I just saw this, but looks good! I never reinstalled my ground wires after the engine ordeal, amongst other things. I have such a list of things I currently own that I have yet to install, we could have a damronjr install meet just to put it all on and spend all day doing it! lol
Re: (02csnow)
Posted: Mon Apr 16, 2007 10:42 am
by BlueCrush
Snow: The lengths are 18", 22", 26", 32", 38". I used the 18" from the alternator bracket to the passenger's side chassis.I used the 22" from the driver's side chassis, under the stock airbox to the battery negative terminal.I used the 26" from the passenger's side chassis to the rear valve cover.I used the 32" from the negative battery terminal, under the battery to the tranny.I used the 38" from the rear valve cover to the tranny.
Re: Lineage Ground Wire Kit Installed (damronjr)
Posted: Mon Apr 16, 2007 10:47 am
by BlueCrush
Quote, originally posted by damronjr »For some reason I just saw this, but looks good! I never reinstalled my ground wires after the engine ordeal, amongst other things. I have such a list of things I currently own that I have yet to install, we could have a damronjr install meet just to put it all on and spend all day doing it! lolThanks, Jason. I am getting great use out of your S/C intake tube, too.You should get Mrizzle and Psychobroker to help you out.
Posted: Mon Apr 16, 2007 11:29 am
by damronjr
Quote, originally posted by BlueCrush »Thanks, Jason. I am getting great use out of your S/C intake tube, too.You should get Mrizzle and Psychobroker to help you out.Yeah, in all the time I have been here I have yet to meet Christian and can't get Mike to come down here for ****!
Re: (BlueCrush)
Posted: Mon Sep 17, 2007 2:06 am
by kunkstyle
If a guy wants to make his own kit, what diameter ends do you need to fit the existing bolts?
Re: (BlueCrush)
Posted: Mon Sep 17, 2007 2:16 am
by northvibe
Quote, originally posted by BlueCrush »Snow: The lengths are 18", 22", 26", 32", 38". I used the 18" from the alternator bracket to the passenger's side chassis.I used the 22" from the driver's side chassis, under the stock airbox to the battery negative terminal.I used the 26" from the passenger's side chassis to the rear valve cover.I used the 32" from the negative battery terminal, under the battery to the tranny.I used the 38" from the rear valve cover to the tranny.Oh just what I needed! my dad got me thick copper cabling to make a ground kit, just needed the lengths! thanks BC.
Posted: Mon Sep 17, 2007 2:55 am
by Kamikaze
Hmm, got me thinking about another mod for the good ole vibe...This might have to be done next weekend. I can't keep up!
Posted: Wed Sep 19, 2007 4:51 am
by Sublimewind
If you guys decid to make your own ground kits up, MAKE SURE you solder the ends, which WILL require a torch... when you do, do the solder, just heat the very end of the ring and let the heat "wick" up the terminal and wire. By doing this you will melt the insulation the least amount possible... also have a vice or a pair of vice grips handy, to clamp the terminal into right after you are done, i will wick away the heat without getting it wet like if you were to dunk it into a water bath.... Also, make sure you tape or heatshrink the ends well, actually you should do both... tape will seal it well, and the heatshrink will make it look good... Good show as always BC...!!!!
Re: (Sublimewind)
Posted: Thu Sep 20, 2007 11:58 pm
by kunkstyle
What about a cold solder tool? Or would that not work for this application?
Re: (kunkstyle)
Posted: Fri Sep 21, 2007 12:08 am
by Sublimewind
Quote, originally posted by kunkstyle »What about a cold solder tool? Or would that not work for this application?I highly doubt it would get hot enough.... I personaly think they are a bunch of crap, but, i'm "old school"You have to have enough heat to get the solder to move via capillary action. If you don't you end up with a "cold" solder joint, which is useless... If the solder don't flow, then it don't go.... You can also buy adhesive lined heat shrink... no need for tape...
Posted: Fri Sep 21, 2007 2:06 am
by 98ex
Blue, how bought a link to the ebay store you got your kit from(or the seller)
Re: (98ex)
Posted: Fri Sep 21, 2007 2:08 am
by BlueCrush
If you do an Ebay search for Lineage Ground Wires - they will come up.
Re: (BlueCrush)
Posted: Fri Sep 21, 2007 2:20 am
by 98ex
Quote, originally posted by BlueCrush »If you do an Ebay search for Lineage Ground Wires - they will come up.This it?http://cgi.ebay.com/ebaymotors...ZWDVWIt does not mention how long the cable is or how many (if they are pre cut)
Re: (98ex)
Posted: Fri Sep 21, 2007 2:24 am
by kevera
"4GUAGE, 21MM2 STANDARD OXYGEN FREE CABLE 5 POINT SYSTEM"It doesn't say how long but how many.
Re: (98ex)
Posted: Fri Sep 21, 2007 2:37 am
by BlueCrush
Quote, originally posted by 98ex »This it?http://cgi.ebay.com/ebaymotors...ZWDVWIt does not mention how long the cable is or how many (if they are pre cut)Yes, that is the one. I list the lengths after I measured them in my first post. I also list what lengths I connected to which locations a little way up in this thread.
Re: (BlueCrush)
Posted: Sun Jun 01, 2008 8:32 am
by BlueCrush
Added new pics back into the first post.
Re: (BlueCrush)
Posted: Fri Nov 21, 2008 4:17 am
by milocas
I know this thread is old.....But have you notice any difference since 5 months ago?
Re: (milocas)
Posted: Fri Nov 21, 2008 9:54 am
by Herb
He doesn't have them anymore. I bought them off him and they just arrived in mail today.Won't have time to do anything about them until maybe next weekend though
Re: (milocas)
Posted: Sun Nov 23, 2008 4:35 am
by Sublimewind
Quote, originally posted by milocas »I know this thread is old.....But have you notice any difference since 5 months ago? You won't notice a huge difference, but you may notice a slight bump in milage, easier starting.. dimming lights might be less... it's a support mod..
Re: (Herb)
Posted: Wed Dec 03, 2008 12:15 pm
by Herb
Well I finally put them on and took a short test drive. It might be all in my head but it does seem to feel a bit peppier and the throttle response seems improved as well.
Posted: Wed Dec 03, 2008 9:10 pm
by Sublimewind
That is another possible side benifit to that... The electronics have an easier time recieving current through the system... that's why I mentioned the possible milage bump and easier starting to...
