Turn signal / head light dimmer switch replacement
Posted: Tue Mar 13, 2007 9:24 am
by omegabrian
I need to replace the turn signal / head light dimmer switch in my 2005 Vibe. I've tracked down an Acdelco part number - D6253C. For the life of me, I can't find anyone who sells it.I tried Auto Zone, they said they can't even get. I tried O'Reilly's, they said they'd look it up and call me back, but they never called back.Does anyone know of a store, online or otherwise, where I could buy this part? Thanks.
Re: Turn signal / head light dimmer switch replacement (omegabrian)
Posted: Tue Mar 13, 2007 9:27 am
by kevera
I can't find that number but try here.You will have to search a little.You could also go to Toyota,they should have it.http://www.trademotion.com/par...13761Edit:The Toyota #84140-02170-switch-multi-function w/foglamps.Here is the Gm onehttp://www.trademotion.com/par...gid=1Hope this helps.
Re: Turn signal / head light dimmer switch replacement (kevera)
Posted: Tue Mar 13, 2007 9:47 am
by omegabrian
Thank you very much.You have been a tremendous help.
Posted: Tue Mar 13, 2007 9:49 am
by kevera
No problem.
Posted: Tue Mar 13, 2007 9:24 pm
what circumstances make you need to replace the switch?Would be great if you can follow up with a description of the task in case somebody else needs to do it at some point Welcome to genvibe!
Re: Turn signal / head light dimmer switch replacement (joatmon)
Posted: Tue Mar 13, 2007 10:32 pm
by omegabrian
Conditions eh? LOLIt was a combination of my having a bad day and a construction worker paving a road that was a detour to begin with who wouldn't let me turn where I wanted. I got Irritated that he was blatantly ignoring my turn signal I sorta ripped the turn signal wand out of my steering column. Yeah, real mature, right?I tried to piece it back together, but there's too much broken plastic.I'll let you know how it worked out.
Posted: Tue Mar 13, 2007 11:06 pm
by Baltovibe
Any chance it could be covered under warranty?
