Aftermarket Crossbars
Posted: Sun Mar 11, 2007 8:07 am
by shane_c
Does any one Thule or Yakima crossbars? If so what was the part # and price. Any advantages of these brands over putting stock crossbars on?
Re: Aftermarket Crossbars (shane_c)
Posted: Sun Mar 11, 2007 8:49 am
by prathman
I looked at the Thule cross bar products before buying the GM "Utility Bars" for our Vibe from:http://pontiac.autowebaccessor...8.phpThey looked very similar and the GM ones may be made by Thule based on their appearance. However, we ordered the ones above because:1) They were less expensive.2) The local Thule dealers didn't have quite the right model to fit the Vibe factory racks. What they had would fit but not as securely as it should.3) The GM Utility Bars included locks which were an extra cost option from the Thule dealers.I was happy with the Utility Bars. They installed easily and come off in just a few seconds when not in use. We used them to move a couch from CA to WI and they were secure on the trip, even during some stretches with very strong side winds. (But gas mileage did suffer - couches aren't particularly aerodynamic.)They looked like they could probably take the standard Thule accessories, but I haven't tested that to be sure.
Posted: Sun Mar 11, 2007 9:04 am
by djb383
Yeah, I have the same bars as prathman, hard to beat.
http://www.gmgoodwrench.com/ac...1.jpg
Re: Aftermarket Crossbars (djb383)
Posted: Sun Mar 11, 2007 10:29 am
by vibe04
I may be willing to sell you my cross bars, all I need to do is talk it over with the wife.
Posted: Wed Mar 14, 2007 5:51 am
by shane_c
So are the utility bars more practical then the older Oval ones? I'd be looking to maybe put a cargo bag or box and at some point down the road would like to be able to transport a canoe or kayak's.
Posted: Wed Mar 14, 2007 6:12 am
by shane_c
Quote, originally posted by djb383 »Yeah, I have the same bars as prathman, hard to beat.
http://www.gmgoodwrench.com/ac...1.jpgDo you have a pic of them installed on your car. The one on the GM site is pretty small.
Posted: Wed Mar 14, 2007 10:28 am
by djb383
Hope this helps. They're on and off in just seconds and lock with a key.clickclick
Posted: Tue Mar 20, 2007 3:01 am
by shane_c
Just what I was looking for. Does the antenna get in the way when you're carrying stuff up there? Is it hard to remove the antenna?
Re: (shane_c)
Posted: Tue Mar 20, 2007 3:15 am
by djb383
The antenna unscrews from the base so you can carry something wide and flat, no problem.
Posted: Mon Mar 26, 2007 6:57 am
by ebslopp
Quote, originally posted by djb383 »Hope this helps. They're on and off in just seconds and lock with a key.clickclickThese are identical to the Thule 751 Rapid Rail, in case anybody wanted to know. Here is the Thule manual
http://www.thuleracks.com/thul...t.pdf
Posted: Mon Mar 26, 2007 11:49 pm
by shane_c
djb383,If you don't mind.... could you measure from the roof to the top of the bar at the back. I'm thinking if I got the crossbars that I would also get a short antenna so that in the event I was to put something up there I wouldn't have to take the stock one off.
