Amsoil/synthetic two stroke oil?
Posted: Tue Mar 06, 2007 10:40 am
The debate on which oils is best for our vehicles is/will always be ongoing.However, to those of you out there that run two stroke motors that require you to premix your fuel/oil.....do you run a standard two stroke oil and mix to the recommended ratio or are you currently using a synthetic 2 stroke oil like Amsoil?Some of my "toys" that require me to premix are a leaf blower, weed eater, chain saw and a ice auger. Different requirements for ratio blends. I have since moved to a synthetic (I believe it was a 50:1 ratio that replaced everything) and it worked well and the ratio was easy to deal with.Anyone here ever try the Amsoil Sabre (I believe that is what it is called) I was given some of this and apparently it is their high end stuff that you mix 100:1 for all your two stroke applications.....Anyone using this? A bit nervous to try it....I have heard from people that swear by the stuff and that it will be plenty fine...and I have heard from some people that say it's nothing but trouble.....I am down to my last half tank full in my ice auger....so it's about time to mix up another gallon of 2 stroke fuel.Now I come to those of you who run two strokes......what are your thoughts/opinions?
