GT/XRS Exhaust Clips
Posted: Tue Mar 06, 2007 9:26 am
by LUVROK
This post is for GT/XRS exhaust clips and comments only. Please do not post if you are only posting to say your Base/XR/supercharger sounds better because it doesn't. I will accept posts of your Base/XR exhaust only if there is clearly a GT/XRS smoking your Base/XR in the background.*All video/sound taken with Sony Ericsson w810i walkman/camera phone.*LUVROK Clip # 1 - my 05 Vibe GT with Magnaflow catback exhaust (GT / XRS model) & Injen CAI (2004 XRS model). Recorded from full stop through lift @ 1st & 2nd gears to 5k RPMs in 3rd gear, then cruising in 4th or 5th at 2.5k. Camera phone starts off lens down and mic up on passenger seat riding shotgun with a BK chicken sandwich and fries and eventually gets lifted to see gauges, road and stereo with a good background tune ending the clip.http://webpages.charter.net/da...4.3gpExecutive Summary:No Base/XR clips allowed. As I add additional performance parts to my 05 GT I will add new clips allowing you to hear the raw power from that which we call the GT/XRS.
Re: GT/XRS Exhaust Clips (LUVROK)
Posted: Tue Mar 06, 2007 9:43 am
by kevera
Sounds great,but loose the attitude.
Re: GT/XRS Exhaust Clips (kevera)
Posted: Tue Mar 06, 2007 9:53 am
by BlueCrush
Quote, originally posted by kevera »Sounds great,but loose the attitude.He's just playin'. sounds good though.This post will self destruct in 5, 4, 3, 2, 1, ......
Re: GT/XRS Exhaust Clips (BlueCrush)
Posted: Tue Mar 06, 2007 5:14 pm
by Mavrik
what ever... I have a car being built right now that sounds better stock and could beat a GT in reverse. And your GT sounds no different then my current set up base Vibe with magnaflow intake. You have to keep in mind its the same cylinder set up between the two engines. We may not have lift but our engine tones are the same.I should post some of my sound clips from the track.
Posted: Tue Mar 06, 2007 9:48 pm
by drunkenmaxx
blah, the base and GT sound the same. the weedeater just goes through more RPMs in the 2zz. ... the raw power of 125 lbs of torque.
Posted: Wed Mar 07, 2007 1:32 am
by Celtic_Curse
Sounds good. they should use your clip for a commercial simular tothe one on the radio regarding the new Civic SI hitting Redline. They play it on the radio out here all the time.Queston though what is the HP of the '05 GT stock?
