AC temp
Posted: Fri Feb 21, 2003 11:54 am
by kaybeejay
What temperature is the AC supposed to come out of the Vibe vents at? I swear mines are way way weak. I read somewhere on this board that its supposed to be something like 34 degrees. Can anyone confirm that?
Re: AC temp (kaybeejay)
Posted: Fri Feb 21, 2003 12:31 pm
by NovaResource
34 degrees!? Are you going to hang meat in your Vibe? Just kidding but 34 is not realistic. 38 at best but anywhere from 38-40 is normal.
Re: AC temp (silverawd26)
Posted: Mon Feb 24, 2003 3:10 am
by Triton
Hang meat! That is funny. I am waiting until it gets a little warmer to check the temp of mine. I have seen some other threads that have said they needed to take their Vibe in to get the temp right in the A/C.
Re: AC temp
Posted: Tue Feb 25, 2003 8:14 am
by DopeVibeGT
BTW, FYI. I read somewhere where you should run your AC every month for at least 10 min to make sure everything stays sealed, even in 10 degree weather.
Posted: Tue Feb 25, 2003 9:52 pm
by Triton
I have had my Vibe for two months and have turned my A/C on a at least once that I can remember. It might be a good idea to do this once a month though. Thanks for the tip.
Re: AC temp (Triton GT)
Posted: Tue Feb 25, 2003 10:06 pm
by NovaResource
Yes, running the A/C in the winter helps lubricate the seals in the system to prevent them from leaking. But remember, the A/C is running when the defroster is on. The light doesn't illuminate but the A/C is running. So if you are running the defroster in the winter you are running the A/C.
Re: AC temp (NovaResource)
Posted: Tue Feb 25, 2003 10:41 pm
by Triton
Awesome Nova! I forgot that the compressor comes on. Is that what needs the movement to help keep the seals lubricated? Anyways, I use my defroster quite a bit here so I don't think I should have any problems.
