car running like crap
Posted: Sun Mar 04, 2007 1:33 am
by metso
had some missfire codes on my vibe,,changed the plugs,air filter and pcv and cleaned the maf and tb,,,,still slightly missfires but not enough to bring on the cel,,,,,,,,,,,,i dont know what to do??brought it to toyota,,,checked it and said its running fine,,,but its not,,dont wanna bring it back to gm,,,their answer was to replace the plugs and erase the codes,,,,well that didnt work,,,toyota said they could check the freezeframe??if the cel comes again,,,,,,,,,,,i dont know what to do??wait for a cel,,or change the o2 sensor????car seems like its lacking air to breath or fuelsome feedback please
Re: car running like crap (metso)
Posted: Sun Mar 04, 2007 2:39 am
by Raven
They're watering down the gas to make more of it because of the Ontario gas shortage.
Posted: Sun Mar 04, 2007 3:41 am
by metso
this all started b4 the shortage,,,,im thinking its a bad maf
Posted: Sun Mar 04, 2007 12:12 pm
by metso
im going to order one tomorrow,,,ill install it and let you all know how the car runs after,,,,,im 99% its the maf,,,,,there is a hot and cold wire in it that detects the temperature of the air along with the volume,,this all started the first day it went below -1,,,if im wrong my wife will kill me
Posted: Sun Mar 04, 2007 12:53 pm
by kevera
the maf sensor is like 200 bucks.I would check Toyota first.I would make sure that's the problem before wasting your cash.
Posted: Sun Mar 04, 2007 1:27 pm
by northvibe
maybe its the o2 sensors? theres 2 one on the intake and one on the exhaust if im not mistaken and if one is giving the wrong numbers it could mess some stuff up. Do you have a cai or any mods? or are you stock?
Posted: Mon Mar 05, 2007 12:12 am
by ToolGuy
Have you put a bottle of Chevron Tech fuel system cleaner in the car? Do not use anything else if you have not. I would start here, cheaper than a sensor.
Re: car running like crap (MiVibe-ToolGuy)
Posted: Mon Mar 05, 2007 12:38 am
by BlueCrush
Also, make sure all of your VSV/Evap lines are connected properly.
Posted: Mon Mar 05, 2007 1:11 am
by metso
installed a new maf sensor today,,,car has its power back,,,,,b4 it felt like my timing was retarded but now it seems a lot better
Posted: Mon Mar 05, 2007 1:20 am
by BlueCrush
Good to hear! That must have been you problem, like you suspected.
Posted: Mon Mar 05, 2007 1:22 am
by Raven
Quote, originally posted by metso »installed a new maf sensor today,,,car has its power back,,,,,b4 it felt like my timing was retarded but now it seems a lot better How much was it here in Canada?
Posted: Mon Mar 05, 2007 3:24 am
by metso
$214
Posted: Mon Mar 05, 2007 3:28 am
by tcam
out of curiosity, what does it feel/sound like when u have missfiring?
Re: car running like crap (tcam)
Posted: Tue Mar 06, 2007 4:42 am
by ToolGuy
From my experience it is like a stumble, jolt or a pause while the engine is running. Picture yourself stopped at a traffic light and you feel a thump, almost as if someone tapped the car. That is what it feels like. If the engine is turning higher RPMs, such as you are moving, the jolt is usually worse. Sometimes you get a check engine code, sometimes not. Depends on how bad the miss is usually.
Posted: Wed Mar 07, 2007 11:35 pm
by metso
well guys my vibe is still running like crap after my new mass air flow sensor,,,it ran alright for a day but then it was back to crapville,,,brought it to g.m. today,,,they put it on a scope and its running on CLOSED LOOP,,,,,as opposed to open loop,,,they said that its running on closed loop way to soon,,,,they suspect its the o2 sensor but are going to do some further investigating,,i will defenitely fill u all in with the outcome
