oxygen sensor help
Posted: Mon Feb 19, 2007 12:55 pm
by metso
where is the first oxygen sensor??(not the one by the cat)the one in the exhaust manifold,,,,,,some pics would be great and some help on how to get at it...i think the heat shield is in the waythanks
Re: oxygen sensor help (metso)
Posted: Tue Feb 20, 2007 1:54 am
by trimovingxr
Sorry, this is the only picture I have of O2 #1 (pre-cat sensor). And the exhaust manifold is already removed from the car, during install of DC header. This is what you will see after removing 4 bolts holding upper heat shield. It's possible to remove the 02 sensor w/ exhaust still on car, but it's not easy because the sensor is located down low and it's tight. You'll be working in the space between the valvle cover and firewall, or underneath the car. You can use a special 02 socket and breaker bar + extensions, like I did. Or, you can use a 7/8" box wrench, if it's not too tight.
Re: oxygen sensor help (trimovingxr)
Posted: Tue Feb 20, 2007 6:26 am
by satur9
the wires rn thru the heatsield . i didnt even take mine off. its different for a gt though.
Re: oxygen sensor help (satur9)
Posted: Tue Feb 20, 2007 8:48 pm
Here's a pic showing the first one on my 03 BaseQuote, originally posted by trimovingxr »You can use a special 02 socket and breaker bar + extensions, like I did. Or, you can use a 7/8" box wrench, if it's not too tight.One of those special sockets would be handy, required if you don't pull the heat shield. I didn't know such things existed. I usually spend more time figuring out how to do a task with the tools that I have than buying the right tool for the job.
Posted: Thu Feb 22, 2007 9:28 pm
by metso
thanks guuys your all the bet
