Front wheel well cover removal?
Posted: Thu Feb 15, 2007 11:59 pm
by jkm311
Between the front tires and the bumper, how do you remove or how is the panel secured that lines the wheel well just below the headlights? I don't seem to see any screw heads, so how is it attached? Any old threads on this? I seem to remember somebody exposing the CAI they ran down in that space, and posting the shots of it. Thanks, Vibers.
Re: Front wheel well cover removal? (jkm311)
Posted: Fri Feb 16, 2007 12:43 am
by Sub-Vibe-R
Do you mean the platic inner fender?If so, to remove it completly, you have the remve 2 screw who link it the the bumper, then the 5 push clips (4 in the fender, 1 under the car).After this, you have to remve the 2-3 screw on the edge of the fender, then remove the cladding. You have to pull hard since it is clipped.
Re: Front wheel well cover removal? (Sub-Vibe-R)
Posted: Fri Feb 16, 2007 1:36 am
by jkm311
Basically, I just need to get my arm in the space behind the headlight on the passenger side. Just screws in the way, if I am reading your post correctly...
Posted: Fri Feb 16, 2007 2:53 am
by Sub-Vibe-R
To do this, remove the 2 screw and the push clip who link the bumper and the inner fender.It is also a good idea to remove the push clip who attatch the inner fender to the fender. After this you will be able to access this area.
Posted: Fri Feb 16, 2007 2:54 am
by kevera
Sub-Vibe-R is correct.The screws and the push clips and it will come out.
Re: Front wheel well cover removal? (kevera)
Posted: Fri Feb 16, 2007 4:02 am
by jkm311
Thanks for the help, guys...
