I get shocked every time I exit the car
Posted: Sat Feb 10, 2007 1:08 am
by gdizzle
Is this some oddity with my Vibe or is it happening to others? I get in, drive around, park, get out, then when I touch the door to close it....SHOCK. Basically happens every friggin time. Any ideas???? And yes I am wearing rubber sole shoes.
Re: I get shocked every time I exit the car (gdizzle)
Posted: Sat Feb 10, 2007 1:16 am
by keithvibe
It's a common problem with most cars. At one point or another I have be shocked by every car I own. It's weather related I assume.
Posted: Sat Feb 10, 2007 1:23 am
by 02csnow
Same thing happens to me all the time, but i use to it b/c im an electrician.
Re: I get shocked every time I exit the car (02csnow)
Posted: Sat Feb 10, 2007 1:59 am
by tcam
haha. happens consistently to me too. and i try to avoid it a lot of the time and probably end up looking pretty wierd to people who are watching me exit the car. lol
Posted: Sat Feb 10, 2007 2:18 am
by CCD
Ever heard of static electricity? Try wearing fleece on a zero humidty day. You will pop the crap out of yourself all day. When I used to install car audio people accused me of causing it all the time.
Posted: Sat Feb 10, 2007 3:12 am
by vibe-04
You generate static when you spin to get in and out of your seat. Hold the door pillar when spinning to load balance your body in respect to the car then spin/swivel whatever to get out. This happens predominantly in winter due to low humidity where excess electrons are not spent through the air as in summer when it is damp(er). Since the car is not grounded (isolated by the rubber tires) you-the human object- is generating an excess in static electricity in relation to the object being the car and presto when you finally touch the load is passed as a zap. You could also wearing a grounding strap from your wrist or ankle to the car's body.Ha....I need to get out more.Andrew
Posted: Sat Feb 10, 2007 4:24 am
by WaveAction
i thought it was all about friction between two materials? i.e. rubbing ur feet along a carpet then touching something..would generate a shock..same thing would be in a car..ur feet constantly moving..plus ur body rubbing against the seat would do the same thing
Re: (RedFire2K)
Posted: Sat Feb 10, 2007 4:32 am
by vibe-04
Yes, the friction generates the static, the relative difference between you and the car is what causes the discharge and "zap!"
Posted: Sat Feb 10, 2007 5:14 am
by Raivis
cold weather makes it worsei have been getting shocked alot especially by my wifes cavalier
Posted: Sat Feb 10, 2007 8:47 am
by zionzr2
before you get out touch your key to something metal and you wont get zapped
Re: (zionzr2)
Posted: Sat Feb 10, 2007 11:30 am
by pmh013
Put a fabric softener sheet in the pocket of your jacket. Helps cut down on static a lot!
Re: (pmh013)
Posted: Sat Feb 10, 2007 9:32 pm
by Tubaryan12
Quote, originally posted by pmh013 »Put a fabric softener sheet in the pocket of your jacket. Helps cut down on static a lot!and you'll smell good too
Re: (Tubaryan12)
Posted: Sun Feb 11, 2007 10:18 am
by Whelan
Just make sure if your at the gas station and you get back in your car you touch the car before you touch the gas pump again. Discharge the static.
Re: (Whelan)
Posted: Sun Feb 11, 2007 10:20 am
Quote, originally posted by Whelan »Just make sure if your at the gas station and you get back in your car you touch the car before you touch the gas pump again. Discharge the static.Some states have actually enacted laws forbidding you to get back in the car once you've gone near the pump.I have the same issue in my G6 too. As many have said, the weather definitely plays into it.
Posted: Sun Feb 11, 2007 2:24 pm
by binary
I was getting the same zap - even through leather gloves!I grabbed a roll of aluminum tape from work and ran a ground strip from under the seat, through the slot where the seat and back meet - and then left a few more inches exposed and stuck to the back... it's really cut down on the amount of static I build up getting out of the car.I think to eliminate all of it, I would run the tape up the outside left side of the seat and ground it under on the rail or spring.The tires really don't insulate you - it's all the damn plastic in the car. If the steering wheel, shifter, or handle above the door was grounded, you'd be able to painlessly discharge (ugh... never thought I'd type that here) your static... but with all the plastic, you build up quite a charge sliding out of the seat and BANG, you touch the metal and even it all out.
Posted: Sun Feb 11, 2007 9:49 pm
by vibe-04
Touch the metal (door pillar/roof) with your bare hand as you are sliding in an out and there will be no static to discharge. You will be constantly equalized.
Posted: Sun Feb 11, 2007 10:01 pm
by zionzr2
FOr another blast from the pasthttp://forums.genvibe.com/zerothread?id=15979
Re: (zionzr2)
Posted: Mon Feb 12, 2007 12:25 am
Quote, originally posted by zionzr2 »For another blast from the pasthttp://forums.genvibe.com/zerothread?id=15979or http://forums.genvibe.com/zerothread?id=7547
Re: (joatmon)
Posted: Mon Feb 12, 2007 12:35 am
by drunkenmaxx
Posted: Mon Feb 12, 2007 12:40 am
by ToolGuy
My 98 Z24 Cavalier did this to my wife every time! Not ever me though! SHe hated the car for that and was glad I got rid of it!
Re: (vibe-04)
Posted: Mon Feb 12, 2007 3:17 am
by kcorona
Quote, originally posted by vibe-04 »Touch the metal (door pillar/roof) with your bare hand as you are sliding in an out and there will be no static to discharge. You will be constantly equalized. Yup. OR if you exit the vehicle w/o touching any metal, after you step out of the vehicle, only touch the WINDOW when you close the door. Touching glass won't shock you.
Re: (kcorona)
Posted: Mon Feb 12, 2007 10:38 am
by bogey523
One thing that has worked for me is to spray the car seats with Static Guard.
Posted: Tue Feb 13, 2007 2:15 am
by engineertwin2
It happens a lot in the winter. As cold nights condense the moisture out of the air, the air dries up and has greater static potential. Remember, pure water doesn't conduct electricity very well and humidity greatly reduces the zap.
Re: (bogey523)
Posted: Tue Feb 13, 2007 11:30 am
by tcam
Quote, originally posted by bogey523 »One thing that has worked for me is to spray the car seats with Static Guard. (removed)!!! are you serious? where is that sold? lol
Re: (bogey523)
Posted: Tue Feb 13, 2007 4:03 pm
by My06Vibe
Quote, originally posted by tcam »(removed)!!! are you serious? where is that sold? lolYes, Static Guard works. I haven't used it on my Vibe but it worked on my old car. I probably bought it from Target or Wal-mart.
Re: (My06Vibe)
Posted: Thu Feb 15, 2007 7:42 am
by bogey523
Yep it's found at most grocery and discount stores. I actually have a free sample I got and keep in my glove compartment. You do have to reapply every few weeks to month. But it really works.
