reverse wire for nav unit
Posted: Fri Feb 09, 2007 11:14 pm
by dakranii
I'm installing a nav unit in my vibe and I need to locate the reverse wire. I see that it's a red/black wire in a 10 pin connector "front of the fuse box", but there is a lot going on there. I took a few pictures of what I think it might be.
Re: reverse wire for nav unit (dakranii)
Posted: Fri Feb 09, 2007 11:16 pm
by dakranii
This is from above the fuse box. I removed the little pull out tray to the bottom left of the steering wheel and took this picture through that hole. The fuse box is on the bottom of the picture and there is a white connector on the right with a red/black wire in it.
Posted: Fri Feb 09, 2007 11:17 pm
by dakranii
This is taken from below, with the fuse box being the part with all the writing on it. There is a connector in the bottom left of this picture that has two red/black wires coming from it.
Posted: Fri Feb 09, 2007 11:50 pm
Hre is what I have, this PDF shows the reverse wire available in several places.The gray junction with three wires marked 3A is above the glove compartment, I have pulled that down to rewire a thing or two, might be easier to get to one of those wires there.The gray block with two wires, labelled 1k and 1D is over at the fuse block your pictures show, although I can't really say which is from the pics.1K is on the top of the fuse block, 1D is on the bottom
Re: reverse wire for nav unit (joatmon)
Posted: Fri Feb 09, 2007 11:54 pm
This pdf has the location/pinout of the wires, coded referenced to the reverse light pdf.The wires marked 3A (pins 1, 2 and 3) in the junction box above the glove compartment are shown n page 10 of 14. The wire on top of the fuse block labelled 1D (pin 6) is on page 6 of 14, and 1K (pin 9) on the bottom of the fuse block is on page 5 of 14
Attached files relayloc.pdf (206.5 KB)
Posted: Sat Feb 10, 2007 10:50 pm
by dakranii
Thanks so much for those pdfs. They really helped, I was able to locate it above the glovebox. I already had the glovebox removed to get the VSS wire, so it was relatively easy to locate there.
Posted: Sat Feb 04, 2017 5:56 pm
by bitmap
dakranii wrote:I was able to locate it above the glovebox. I already had the glovebox removed to get the VSS wire, so it was relatively easy to locate there.
First, I have a 2003 Pontiac Vibe GT w/ Manual Transmission. I'm in the process of trying to figure out where the reverse light wire is and found a red-black colored wire above the glove box and connected a t-tap and whether the the vehicle is in reverse or not their is about 12 VDC. See image below.
- wires.jpg (83.49 KiB) Viewed 4534 times
Any insight into where I went wrong? Also, are there multiple wires with red-black insulation? Any insight is appreciated. Thanks.
Posted: Tue Feb 07, 2017 12:47 pm
by 302LVR
bitmap wrote:dakranii wrote:I was able to locate it above the glovebox. I already had the glovebox removed to get the VSS wire, so it was relatively easy to locate there.
Did u need to locate this cable in order to use a rear-view camera? Just asking cuz i'm about to install a dvd player with back-up camera in mine and i would like to know which wire i'll need to tap in the future in case i end up installing the rear camera since it's pretty neat to have. Thanks ahead of time.
Posted: Wed Feb 08, 2017 9:17 pm
by bitmap
302LVR wrote:Did u need to locate this cable in order to use a rear-view camera? Just asking cuz i'm about to install a dvd player with back-up camera in mine and i would like to know which wire i'll need to tap in the future in case i end up installing the rear camera since it's pretty neat to have. Thanks ahead of time.
The camera is easier to find the correct wire because you can physically connect it very near the reverse light and then run the necessary connections to your head unit or whatever you're viewing from. I'm trying to get the cable in the front, where there are many other wires, because I was not planning to use a camera*. My use is for dead reckoning of navigation system -- I have the vehicle speed sensor (VSS) hooked up so it works well under bridge, in tunnels, underground parking, et al going in a forward direction where satellite connections are poor or nonexistent, but the problem is when the reverse wire is not hooked up and you're driving in reverse, the unit thinks it is going forward and messes up a little -- not a big deal but I'd like it to be as good as possible.
* I now think it may be easier to connect a reverse camera based on the fact that there hasn't been a response specifically to which wire I should be tapping yet.
Posted: Thu Feb 09, 2017 10:01 am
by 302LVR
Good thinking, hadn't thought about that. Indeed if u just splice into the reverse light i'm pretty sure you'll get the signal as soon as the reverse lights come on. Besides that, hope you can figure out your issue very soon.
