Intake Manifold Removal
Posted: Wed Feb 07, 2007 11:40 am
by tcam
Anyone ever taken out there intake manifold? how difficult is it to do? any suggestions?
Re: Intake Manifold Removal (tcam)
Posted: Thu Feb 08, 2007 2:25 pm
by tcam
any tips at least?? is an air-compressor a must have for something like this?
Posted: Thu Feb 08, 2007 7:52 pm
by Raven
It should be simple, it's easy to get to on the front of the engine. An air compressor is not needed. It's plastic, so be careful with the torque specs when you reinstall it.
Re: Intake Manifold Removal (Sunny)
Posted: Thu Feb 08, 2007 7:58 pm
by kevera
As far as I can see,there are 4 bolts and 2 nuts holding it on.Then the throttle-body ,hoses and throttle cable(or not if you have DBW).Doesn't look too hard,remember the gaskets too.
Re: Intake Manifold Removal (kevera)
Posted: Fri Feb 09, 2007 4:52 am
by tcam
Alright, this is starting to sounda little better. lolSunny, my manifold is actually not the plastic one since I'm a 2003. But that won't make the torque specs any different I don't think?Kevera, do u think I need to buy new gaskets or could I just re-use the old ones when I put the manifold back on? and is there any threat of faultering the throttle cable when I take off the TB?
Posted: Mon Feb 12, 2007 5:56 am
by kevera
Sorry for the late reply as I have the flu.I would buy a new gasket and when you remove the throttle-body use white-out to mark the cable so it goes back to the original place.Are you painting the manifold?
Posted: Tue Feb 13, 2007 4:28 pm
by tcam
ooo, good idea. thanks no, I'm having the TB bored out, and the IM port matched.
Posted: Tue Feb 13, 2007 8:54 pm
by kevera
If your going through all that work,I would replace the gaskets.But,you will have to port match them too.I'm doing that in the summer,let me know how it turns out.Good luck
Posted: Wed Feb 14, 2007 10:08 am
by tcam
Quote, originally posted by kevera »If your going through all that work,I would replace the gaskets.But,you will have to port match them too.I'm doing that in the summer,let me know how it turns out.Good luck haha, again great advice. i don't think I would've remembered to have that gasket port matched. very crucial though. lol
