Loud dash rattle above 3500 RPM
Posted: Mon Jan 29, 2007 3:17 am
by shane_c
Since I've installed my intake I've been getting a very loud rattle in the centre of the dash, up by the windshield. It seems to occur above 3500 RPM in 3rd gear. Any idea what it might be, it's driving me insane.
Re: Loud dash rattle above 3500 RPM (shane_c)
Posted: Mon Jan 29, 2007 3:33 am
by ragingfish
If it only appeared after installing an intake, most likely the culprit is the intake itself. Unless they drastically changed the piping, most of the intakes on the market come very close to the driver side strut tower. Under heavy acceleration, or when shifting gears, the engine rocks backward (toward the driver) on it's mounts. That causes the intake pipe to hit the strut tower, producing a very ugly vibration. Try sticking a piece of padding between the intake and the tower, and see if it goes away.
Posted: Mon Jan 29, 2007 3:41 am
by shane_c
Well since I put on the intake the exhaust sound has gotten much deeper. I'm thinking that may be causing things to vibrate more. I will check things under the hood though to see if anything is obvious.
Re: (shane_c)
Posted: Mon Jan 29, 2007 3:42 am
by ragingfish
Quote, originally posted by shane_c »Well since I put on the intake the exhaust sound has gotten much deeper. I'm thinking that may be causing things to vibrate more. I will check things under the hood though to see if anything is obvious. You wouldn't likely hear an exhaust rattle towards the front. It would most likely be under your seat.Try sticking your fingers between the intake pipe and the tower. If you can't easily stick them between the two, I'd bet money that's your culprit.
Posted: Mon Jan 29, 2007 10:20 pm
by shane_c
I had a look yesterday and the only thing it's rubbing on is the plastic part of the stock intake that's still in the fender. I really can't see this being the cause of my rattle. It sounds like something is loose in the dash up around the vent/windshield. I'll keep trying to find it though.
Re: (shane_c)
Posted: Tue Jan 30, 2007 2:33 am
by ragingfish
Quote, originally posted by shane_c »I had a look yesterday and the only thing it's rubbing on is the plastic part of the stock intake that's still in the fender. I really can't see this being the cause of my rattle. It sounds like something is loose in the dash up around the vent/windshield. I'll keep trying to find it though. Ever check your cruise module? Or was it the DRL...I can't remember. One of them, though, is forward of the steering wheel, and is notorious for rattling.
Re: (shane_c)
Posted: Tue Jan 30, 2007 2:49 am
by kevera
Dude what plastic piece is still left in your fender.If it started when you put the intake on,Raging has a great point about it rubbing on the strut tower,you'd probably feel that in the dash.Or the filter in the inner fender,that could touch something in there.If it's in the dash then that's a different story,and probably happened by chance.
Posted: Tue Jan 30, 2007 2:58 am
by shane_c
When I removed the factory air box there is still the piping in the fender from the factory. I left that so air can still blow in from there. The rattle is definately from the dash, towards the centre. It's been driving me insane but like I said only seems to happen above 3500 rpm in 3rd, and sometimes in 4th. It is very coincidental about it happening after the intake went on. I strongly believe it's from the deepness in exhaust tone now and it's vibrating things more.
Re: (shane_c)
Posted: Tue Jan 30, 2007 3:11 am
by kevera
I think my door panels started getting a weird rattle at idle.Did you check if it was your keys rattling.Or change(money) in one of the compartments making that noise.
Posted: Tue Jan 30, 2007 5:27 am
by shane_c
I'm positive it's not keys or money. It's definitely in the dash somewhere. I also have a bad door rattle but I know what that is. When the stereo place put my speakers in one of the screws didn't go into anything so when I tracked the rattle down to the speaker and tried to tighten it the screw just spins around. It rattles at idle, while driving along, and sometimes to certain bass frequencies. So when it gets warmer I'll have to pop the panel off again and fix it.
Re: (shane_c)
Posted: Thu Feb 01, 2007 5:12 am
by Yury
is it -21 on the thermometer on the picture ? a bit chilly...
Re: (Yury)
Posted: Fri Feb 02, 2007 2:02 am
by shane_c
Yes it was. It was about a month or two ago. We had a real cold spell for a week or so with windchills in the -40's.
Re: (shane_c)
Posted: Fri Feb 02, 2007 6:09 am
by kevera
Yury,aren't you from Canada.I gets cold like that here,at least the part of Toronto I'm from.
