05 AWD Intake, MAF in the way?
Posted: Mon Jan 29, 2007 2:52 am
by Whelan
Since the bays are the same, I was almost debating building my own off of the stock piping and just connecting a filter to the pipe where the airbox is. But the MAF sensor is actually part of the box??? It connects into a hard plastic part right where the box connects to the tubing.So how does someone change this around, or do they even sell a filter that incorporates this?I'm assuming that the 03-04 Matrix/Vibe did not have the MAF there hence the ability to put one on. I would go with a warm air shorty, even just like i said with a cone filter at the end of the stock piping, but what to do about the MAF.
Re: 05 AWD Intake, MAF in the way? (Whelan)
Posted: Mon Jan 29, 2007 3:03 am
by kevera
I have an 04 and it is in the same place.You are either going to have to get an intake system,warm or cold air.Or do a ram air type setup.Good luck
Re: 05 AWD Intake, MAF in the way? (kevera)
Posted: Mon Jan 29, 2007 3:05 am
by Whelan
So does that MAF sensor come out? I'm guessing the plastic tube it is in is removable and able to connect to an aftermarket system? I want a ram air where the cone sits where the airbox is now. Too many bad experiences with my civic and the AEM cai to wanna deal with that headache again. I know it doesn't do much unless you add more mods, but one reason I love it is the sound!
Posted: Mon Jan 29, 2007 4:51 am
by kevera
The Maf sensor comes out with the 2 screws.But,disconnect the battery before you take it out,it is very sensitive.The short ram setup is what your looking for.And yes,the Maf will go into a aftermarket intake.Check out K&N,Cosmo,or eBay for a short ram setups.
