New Quebec Drivers handbook for 2007!
Posted: Wed Jan 24, 2007 2:27 am
by ArcsVibe
Wow how times have changed! 1. Turn signals will give away your next move. A confident driver avoidsusing them.2. Under no circumstances should you maintain a safe distance between youand the car in front of you, because the space would be filled in bysomebody else, putting you in an even more dangerous situation.3. The faster you drive through a red light, the less chances you have ofgetting hit.4. Warning! Never come to a complete stop at a stop sign. No one expectsit and it will result in your being rear-ended.5. Never get in the way of an older car that needs extensive bodywork.The other operator has nothing to lose.6. Never pass on the left when you can pass on the right.7. Speed limits are arbitrary figures; given only as a suggestion, and arenot enforceable.8. Just because you're in the left lane and have no room to speed up ormove over, doesn't mean that a driver flashing his high beams behind youdoesn't think he can go faster in your spot.9. Always brake and stare when you see an accident or even someonechanging a tire. This is seen as a sign of respect for the victim.10. Learn to swerve abruptly without signaling. Québec is the home ofhigh-speed slalom-driving; thanks to the Department of Public Works, whichputs pot-holes in key locations to test drivers' reflexes and keep themalert.11. It is tradition to honk your horn at cars in front of you that do notmove three milliseconds after the light turns green.12. To avoid injury in the event of a collision or roll-over, it isimportant to exit your vehicle thru the windshield right away. Wearingyour seat belt will only impede your hi-velocity escape from danger.13. Remember that the goal is to get ahead of the pack of drivers.Thank you, from the Québec Registrar of Motor Vehicles
Posted: Thu Jan 25, 2007 12:04 am
by thebarber
roffle.
Posted: Thu Jan 25, 2007 6:29 am
by Thewhite
excellent Sam! now we have a How To for people coming over here!!
Re: New Quebec Drivers handbook for 2007! (ArcsVibe)
Posted: Thu Jan 25, 2007 7:51 am
by POLO
So i see that from where the majority of the driver have learn there driving. Maybe to add one. When you turn,don't put your flasher,and just wait on the last last moment when the car on your rear are very close to you,then turn
Posted: Thu Jan 25, 2007 12:48 pm
by fredfreedom
That's the consequence of the abandon of driving lessons!
Re: New Quebec Drivers handbook for 2007! (fredfreedom)
Posted: Thu Jan 25, 2007 7:22 pm
by Raven
14. Giving someone the middle finger is a form of praise to acknowledge that the other person has achieved the skills necessary to drive in Quebec.
Posted: Sat Jan 27, 2007 9:14 pm
by Thewhite
15. Right turn on a red light is same as a green light: no stop is required.
Posted: Tue Feb 06, 2007 2:45 pm
by psycho
16. Show no courtesy to anyone
Posted: Tue Feb 06, 2007 2:47 pm
by psycho
17. Remember if you drive into a parking lot, ignore every rule you can think of. No lanes, you can go wherever you feel like in any direction.
Re: (psycho)
Posted: Tue Feb 06, 2007 9:32 pm
by ArcsVibe
Quote, originally posted by psycho »16. Show no courtesy to anyoneWell that is a given
Re: (ArcsVibe)
Posted: Wed Feb 07, 2007 3:49 am
by psycho
Quote, originally posted by ArcsVibe »Well that is a given Well, we need to emphasize it or else, its not clearly mentionned and ppl might forget to do so.
Re: (psycho)
Posted: Wed Feb 07, 2007 3:50 am
by ArcsVibe
Quote, originally posted by psycho »Well, we need to emphasize it or else, its not clearly mentionned and ppl might forget to do so.True very true. I stand corrected
Re: (ArcsVibe)
Posted: Mon Feb 12, 2007 10:14 am
by Thewhite
I transformed this into a PPS, so if you want to share it with your folks at work... enjoy!
Attached files 2007Quebec’sDriver.pps (53 KB)
Re: (Thewhite)
Posted: Mon Feb 12, 2007 10:37 am
by Mavrik
I'm sure I saw that before somewhere but I think you guys have been following that since before 2007
Posted: Thu Feb 15, 2007 5:15 am
by Thewhite
Re: (Thewhite)
Posted: Thu Feb 15, 2007 11:21 am
by psycho
Quote, originally posted by Thewhite »I transformed this into a PPS, so if you want to share it with your folks at work... enjoy!Nice work!BTW, did you do this while you were working?
Re: (psycho)
Posted: Thu Feb 15, 2007 10:41 pm
by xrs06
Quote, originally posted by psycho »Nice work!BTW, did you do this while you were working? I tought I was the only one "surfing" the net while working
Re: (xrs06)
Posted: Thu Feb 15, 2007 10:54 pm
by ArcsVibe
Quote, originally posted by xrs06 »I tought I was the only one "surfing" the net while working Nope lol
Posted: Sat Feb 17, 2007 5:54 am
by Thewhite
no, I made this at home.
