I need some help
Posted: Tue Jan 23, 2007 12:42 pm
by Digger
I need a ING. switched circut under the hood to tap into. Any ideas? I needs to be a 15 amp circut
Re: I need some help (Digger)
Posted: Tue Jan 23, 2007 8:08 pm
by mcgusto82
the ciggarette lighter is ing switched and 15 A. I think..
Re: I need some help (mcgusto82)
Posted: Wed Jan 24, 2007 3:11 am
by Digger
I am looking for one under the hood. I do not want to go though the fire wall if posible.
Posted: Wed Jan 24, 2007 3:13 am
by keithvibe
this may sound harsh.. but a test light is your friend.. start testing one by one
Posted: Wed Jan 24, 2007 6:34 am
by nygiantzz1
I believe I used the horn fuse when I wired in my mirror. I will check later and see what ampearage it's rated for and post the info for you. You could also tap one of the headlight wires and run a 15amp fuse inline as well.
Posted: Wed Jan 24, 2007 8:14 am
by nygiantzz1
I used the left headlight fuse when I installed the mirror, it is a 15 amp ignition switched source. I used 18ga. wire, stripped back about an 1-1/2" and wrapped it around 1 leg of the fuse. The cover for the fuse panel does not pinch the wire when installed. That should work fine for you. There is a good (existing) ground point close by on the driver side strut tower.
Posted: Wed Jan 24, 2007 10:19 am
by Digger
thanks nygiantzz1.I was going to check that tonight. I was not sure if it's power was not cut back in the day time due to the existing DRL.
Re: I need some help (keithvibe)
Posted: Wed Jan 24, 2007 10:24 am
by Digger
Quote, originally posted by keithvibe »this may sound harsh.. but a test light is your friend.. start testing one by one I have one of those and I also use it. Just thought some one might respond with a helpful post about a source they used.
Re: (Digger)
Posted: Wed Jan 24, 2007 10:28 am
by nygiantzz1
It doesn't matter what the DRL circuit draws, the fuse is between the 12V source and the DRL circuit to protect it and the headlights. Your only concern is the current draw on what you are installing. If the accessory installed needs a lot of power, it may cause the headlight to dim or even pop the fuse. In my case, the mirror draws about 0.5 amps, nothing really. What are you wiring in?
Posted: Wed Jan 24, 2007 11:46 am
by Digger
It is a DRL system that turns the blinkers into DRLs. So, when headlights are on the new circate will draw nothing. Thanks. I tested it with my multi tester and it will work great. That what I love about this site. Many good people with good help.
