PCM swap
Posted: Sat Jan 20, 2007 9:12 pm
by Tubaryan12
I have an '05 base and I am almost out of warranty. I only have the "hot soak" issue about once per week at most and I only have to crank it for about6-6 seconds. Even in the winter I have a combined (90/10....mostly highway) mileage of around 30 mpg with an automatic. Some of the folks that did the change are getting lower gas mileage after the change. So, should I try to get this done before I am out of wanrranty or will this still be covered after 36000 miles? Or should I leave it alone because my gas mileage is good and its not worth the risk of lowering it.
Posted: Sun Jan 21, 2007 12:33 am
by CAN-AWD-VIBE
does the US have an extended emissions warranty like we do here?PCM should be covered under Emissions not 3yr/60 (or whatever the miles are)
Re: (CAN-AWD-VIBE)
Posted: Sun Jan 21, 2007 3:02 am
by Tubaryan12
I know US emission warranties are longer than 3yr / 36000 mile. If this part is considered part of that, then I'll quit stressing about it.
Posted: Sun Jan 21, 2007 3:07 am
EDIT: Ok, I'm an idiot. If anyone saw my original post, I was WRONG! Per MyGMLink: 96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM. And what's the "hot soak" issue?
Re: (ragingfish)
Posted: Sun Jan 21, 2007 5:22 am
by Tubaryan12
Quote, originally posted by ragingfish »EDIT: And what's the "hot soak" issue?http://forums.genvibe.com/zerothread?id=20641at least that's what someone called it there.
Posted: Sun Jan 21, 2007 5:39 am
Ah. That's a poorly chosen phrase IMHO. I would think hot start would be a better description. Just my $0.02 though...
Re: PCM swap (Tubaryan12)
Posted: Wed Jan 31, 2007 10:08 pm
by Yury
i didn't know new PCMs reduce mileage ! darn and here i am trying to figure put why my mileage went down.does anybody know roughly how much it decreases ? i am now in 29-32 range. When the car was new I remember getting 34-35 at some point.
Posted: Wed Jan 31, 2007 11:23 pm
by northvibe
Im pretty sure its the pcm's on the new DBW vibes that only have this issue. What you need to do is get the car in before your warranty expires so its on record and then if you have the issue right after the warranty expiration you can still have it covered (this goes for almost all problems) because its documented and if they didnt fix it, they have to considering hte problem happened before the warranty expired and they didnt fix it properly the first time.
Re: PCM swap (Yury)
Posted: Wed Feb 14, 2007 8:49 pm
by jbyerley
I have noticed the same thing. Mine dropped about the same as yours.You would think they would tell you this before you switch.
